WJ spark plug change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > WJ spark plug change
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueStainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 02-18-2005, 11:36 AM   #1
oilcounter
Tomorrow I am going to change out my sparks for the 1st time. I have read all the posts in this forum that I could find for info.
btw - I'm using Champion truck plugs with the copper tips.
I'm nervous but excited about this project. Does anyone have any advice to hand out? Or warnings of things I should avoid during this..
Rob
2000 JEEP GRAND CHEROKEE I-6 (WJ)
All stock except for Mopar 3 disc In-dash CD player
Michelin M/S LTX 255/70/16
Metallic Taupe Jeep Club Member #15
oilcounter is offline   Reply With Quote
Unread 02-18-2005, 11:53 AM   #2
ojingalena
Before you install the new plugs make sure they are the correct ones and be sure they are "gapped" accordingly. Not all new plugs are the correct gap for your application. Check your owners manual for proper gap, or usually on the hood or inside the engine compartment on the emsissions tag.
Make sure no debris is around the plugs before you remove the old ones. Compressed air wooks well. OR a hair dryer to blow away debris.
Do not cross thread the plugs. Use your fingers to make sure they are threaded correctly. Do not over tighten the plugs.
Inspect the plugs for wear and proper firing. They should look used. Not oily, sooty, bent, damaged, fused, etc..
Pull the wires off one at a time by the boots, not the actual wire. (Label if needed)
Make sure the wires are reconnected all the way. You should hear a little snap or feel a slight click.
An old plug wire makes an excellect tool for hard to reach plugs.
Have a beer when finished..
HTH,
Jim
If loving the Buckeyes is wrong....I don't want to be right.
Mine: 95 ZJ 5.2 Quadratrac Char Gold Laredo, Tow Package, K&N FIPK, Kolak Mopar ECU, CatSound, AT50 Muffler, 2" TeraFlex BB, Bilstein 5100's, 265/70-15 110S Dueler AT Revo's. It's a start..more to come
Wifes: 99 WJ 4.0 Laredo pretty much stock....for now.
Mine: 06 KJ Renegade
ojingalena is offline   Reply With Quote
Unread 02-18-2005, 12:54 PM   #3
BostonBull
Make sure when you take your coil rail off that you dont bend/break the wire attached to it at the end near the fire wall. I usually leave it attached and bend the rail out of the way of the plugs. Use some dielectric grease on end of boots and anti sieze around threads. You dont have any wires so it shouldnt take anymore than a half hour!
Wicked Pissah
[SIZE=3][FONT=franklin gothic medium][COLOR=red][B] 81[/B][/COLOR][/FONT][/SIZE]
BostonBull is offline   Reply With Quote
Unread 02-18-2005, 10:55 PM   #4
oilcounter
when I gap the new sparks ( i have a gap tool), do I just use the tool to widen the gap? How accurate do I have to be here? I think I have the gap correct, but didn't know if it was an exact science here or not..
Thanks for the tips. I'll report back on my pending success
R
Unread 02-18-2005, 11:10 PM   #5
josephmartins
josephmartins's Avatar
Precisely
Usually quite a few (if not all) plugs these days come pre-gapped...so the gap will already be pretty close to what you need...if not dead-on.
Just slip the right gap [of the tool] between the electrodes and you should feel just a bit of friction as you slip the tool in and slide it back out.
If it's too tight and the tool can barely slip in I gently rock the tool up and down to open the gap a bit more and try sliding the tool in and out again....be gentle, it's easy to open the gap too much.
There's no science to it.
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8 conversion, <10 miles (FOR SALE, $56,700)
01 WJ Limited, 4.7, 247, black on black, 157k miles (sold)
96 XJ Classic, 4.0, 242, black on grey, 267k miles (sold)
00 XJ Sport, 4.0, 242, fern green on grey, 76k miles (sold)
90 XJ Wagoneer, 4.0, 242, burgundy on tan, unknown mileage (sold)
97 ZJ Limited, 5.2, 249, black on black, 138k miles (wrecked 12/15/05)
98 ZJ Limited, 5.2, 249, burgundy on black, 197k miles (sold)
josephmartins is offline   Reply With Quote
Unread 02-19-2005, 09:19 AM   #6
Stocker
How goes the project? If you need it, here's a site with torque specs and other basic info... http://www.nology.com/torque.html
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline   Reply With Quote
Unread 02-19-2005, 11:29 AM   #7
Scottsdale Jack
A good way to start the new plug in the thread is to slip a piece of fuel line or similar hose over the top tip of the new spark plug. That way when you slide it down the hole you can start the plug in the thread by hand and have a good "feel" for the task. When the plug starts in the thread then you can just give a little tug and the hose will slip off the plug and then you can torque it in.
Scottsdale Jack is offline   Reply With Quote
Unread 02-19-2005, 05:34 PM   #8
oilcounter
I have finished changing the spark plugs. I really enjoyed myself. I am a complete novice when it comes to stuff like this. What a confindence builder..
Everything went smooth.. It was a little tough to get the sparks out from the very back one. Good thing I have small hands.. That boot got in my way a little but I managed nicely.
I encourage anyone who hasn't changed their spark plugs to go ahead and give it a try. It much easier that the instructions let on.
I did notice the old sparks (original w/jeep - currently 70K miles) Most of them were pretty crusty with grayish charing.. one plug was more dark than the others. I dont know if this is typical or not, but I'm glad I changed them]
A HUGE thank you to everyone who offered advice for me!!
Until my next project... (any suggestions )
Rob
