WJ: someone with A/C low/high side pressure expertise? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > WJ: someone with A/C low/high side pressure expertise?
Bead Lock Wheels! Raceline, Trail Ready, & Trail-GearIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 01-13-2009, 09:19 PM   #1
mailforjon
2005 WK
ive been having difficulty with the defrost lately (not defogging well) and assumed i had a bad heater core, broken recirc. door or something like that.
i bought a nice set of A/C manifold gauges and hooked them up with the blower on full blast, and the A/C and RECIRC buttons on. ambient temp. was 30F.
readings start:
LOW: 20psi
HIGH: 100psi
simultaneously and slowly (over 15 seconds or so)
LOW: increases to 35psi
HIGH: decreases to 50psi.
then, the compressor clicks (on/off?) and:
LOW: decreases slowly back to 20psi (creates a vacuum?)
HIGH: side slowly increases back to 100psi.
can anyone with experience with A/C pressures diagnose what is going on?
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline   Reply With Quote Quick reply to this message
Unread 01-13-2009, 09:41 PM   #2
sadass
sadass's Avatar
a little info for you, sounds low!
This is a complicated thing. The high pressure side will measure in excess of 250 psi, but that's not important. When filling 134a, you only need to watch the low pressure side.
When the compressor kicks on (which it will only do when the pressure is above 40 psi) the pressure will drop. If the lines are full enough, the pressure will remain around 40-45 psi while it's running. When the compressor kicks off, the pressure will rise to 90-100 psi., as the high and low pressure sides even out in the expansion tank.
If your lines aren't full enough, the compressor will either not kick on at all, or it will kick on for a second, and the pressure will drop to 20 psi or less, and it will kick off. If the lines are empty enough, it will do this on and off, on and off, pretty frequently, like every 5 seconds or less.
Be sure to hold the cans up-side-down and high in the air as you release them into the system. Otherwise, they will release much slower, as you will be releasing only what gas has expanded. NEVER connect the cans to the high pressure side. They will explode in your hand, not only removing your hand and eyes, but will also freeze your skin instantly.
Just keep applying cans until the pressure remains at 40-45, depending on your vehicle(it will find this pressure on it's own. you will see it remain there and not drop past a point. if it has not found it's point, it will never stop dropping till the compressor kicks off.) Do this a little at a time, stopping to watch the pressures.
Once you reach this steady pressure reading, finish off the can, and you can probably add another can or just a half a can. You don't want to add too much, or else the pressure will build up too much on the low side. If this happens, (and only if you have 134a) you can release the excess pressure from the valve just like you would emptying a tire. Be sure you do this on the LOW side, and do it while the vehicle is running, so you can watch the pressure. Be careful, and wear leather gloves if you have to remove some, because what comes out will freeze your skin.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline   Reply With Quote Quick reply to this message
Unread 01-13-2009, 10:17 PM   #3
Spankee
expansion valve could be faulty if your refridgerant level is good.
Spankee is offline   Reply With Quote Quick reply to this message
Unread 01-14-2009, 04:52 PM   #4
mailforjon
2005 WK
does it matter that it was 30F when i did this pressure test?
-1993 XJ 2.5 [SOLD]
Unread 01-14-2009, 05:25 PM   #5
spenc
when the compressor is idle the pressures will "equalize" at 30 deg outside temp you would expect to see around 25 psi with nothing running, if idle long enough they shoud be the same, only when the compressor is running, will you get the pressure differential that it needs to cool, at such low ambient temps, it is normal for the compressor to run and kick off, this keeeps the evaporator from icing up, be carefull adding too much when it is this cold outside,when it gets hot you could flood the compressor and ruin it
spenc is offline   Reply With Quote Quick reply to this message
Unread 01-14-2009, 06:22 PM   #6
xJoshxx
2012 WK
ussally u check the Level when it's warm dont u? got somebody with a heated garage?
yea if the Regfridge or PUREON now called isnt warmed up the compressor gets a big nasty shot of chunky fluid.
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2
2012 WK2 SRT8
xJoshxx is offline   Reply With Quote Quick reply to this message
Unread 01-14-2009, 06:31 PM   #7
CaseyC
1994 ZJ
All refrigerant cans have the warning to dispense in upright position only. Reasoning for this is you don't want the compresser to get hit by a slug of liquid and hydrolock.....vapor only, it takes time......
Klaus Cook
Houston, Texas
CaseyC is offline   Reply With Quote Quick reply to this message
Unread 01-14-2009, 06:39 PM   #8
xJoshxx
2012 WK
Klaus Cook
Houston, Texas
WHICH IS WHY U WAIT FOR UR JEEP TO WARM UP BEFORE BLASTING THE DEFROST!
2011 WK2 ORA2
2012 WK2 SRT8
Unread 01-14-2009, 08:27 PM   #9
elmer_fud
Klaus Cook
Houston, Texas
agreed, right side up is probably better. Besides, when it is up side down, the top of the can is still filling with vapor at the same pressure as the liquid. it will only fill the ac system until the can and low pressure port are at the same pressure, and this pressure will be the same not matter the position of the can. I would rather take a bit longer than risk killing the AC system
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline   Reply With Quote Quick reply to this message
Unread 01-14-2009, 08:28 PM   #10
elmer_fud
also, I would check the heater core and doors before worrying about the AC to much. Vehicles without AC still have defrost and it works fine once the engine starts to warm up.
Brian
Unread 01-15-2009, 10:23 AM   #11
mailforjon
2005 WK
i thought you needed a functional A/C system to have an effective defrost?
dont you need a working evap to pull the moisture out of the air?
-1993 XJ 2.5 [SOLD]
Unread 01-15-2009, 02:57 PM   #12
elmer_fud
no, you do not need a functioning AC.
As air warms up it can contain more water. The defrost heats the air so it can pick up water off the windshield.
The AC makes the defrost more effective for the first few minutes it is on, but after that it doesn't do much. The defrost blows hot air on the windshield to heat it up a bit and dry off any moisture. Hot air can store more water than cold air, so this is why defrost heats up the air.
The AC makes the defrost more effective when the engine is cold because it cools the air first making the water seperate from the air.
My ZJ doesn't have working AC ( I disconnected it) and the defrost still works fine once the engine starts to warm up slightly. this is because the heat from the engine is transferred to the air. The heat makes the air dryer and removes moisture from the windshield.
does this make since? I am not sure how well I explained it.
Brian
Unread 01-15-2009, 04:01 PM   #13
spenc
the most important question I can think of is: did the a/c work last summer, if so DON"T mess with it!!!
Unread 06-20-2015, 05:45 PM   #14
Andrewc135
So, what should be my step from here on
Clearly i want to release pressure
but from there on?
From what i see the clutch doesn't engage at all...
Had my head gasket redone about 3k miles and 2 months ago...
Andrewc135 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 07:36 PM   #15
Oldfrog
BTW, this is a 2009 zombie thread.
You need to engage the clutch to get a reading. Do this by jumping the high pressure switch.
The low side will go down when the clutch engages. My guess is that it's low on r134. Add some and the clutch will engage without jumping the connector.
Cajun Recipes and Fishing tips
On 7th PCM. Finally got a good one.
Stalling? Work through Zeejay's list
God Bless the Garland, TX Police Dept.
Oldfrog is offline   Reply With Quote Quick reply to this message
