WJ Rear Tow hook Install - JeepForum.com
post #1 of 16 Old 09-17-2005, 09:11 PM Thread Starter
CinciSurWJ
CinciSurWJ's Avatar
I got a used rear Tow Hook from a forum member in JU. Since it did not come with the install sheet iam having trouble in installing it on my WJ.
Basically the rear Tow hook kit comes with a Tow Hook which is already attached to a Bracket and a Brace. Look like I need to bolt the one end of the Brace to the TowHook, but don't know where the other end goes too.
If any one have a rear tow hook on their WJ, can you post the pics of it how it got installed and stuff.
I looked at wjjeeps.com does not give the detailed instruction of the rear tow hook install.
Thanks,
Sur.
2000 WJ 4.0 I6 --> Daily Driver for past 7 year and love it.
BridgeStone Revos 265/70 R16
Kevin's Rock Slider - LP1 model
Kevin's 2.5"BB, DT3000, OME SS, Addco Rear Sway bar
Front Skid & Transfer Case Skid.
CinciSurWJ is offline
post #2 of 16 Old 09-17-2005, 09:12 PM
rrubio
rrubio's Avatar
Thanks,
Sur.
To dark now but I can post a pic tomorrow for you.Pretty much easy to bold on to if I recall..
rrubio is offline
post #3 of 16 Old 09-17-2005, 09:33 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
If you have the tow hitch, why do you want a rear tow hook?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 16 Old 09-17-2005, 09:35 PM Thread Starter
CinciSurWJ
CinciSurWJ's Avatar
Thanks , looking forward to the pic.
I went my dealer today, looking for a WJ with rear tow hook, found out they didn't have any.
post #5 of 16 Old 09-17-2005, 09:36 PM Thread Starter
CinciSurWJ
CinciSurWJ's Avatar
Hunter
My WJ does not have a Tow hitch. I thought of installing a hitch, but I don't tow any.
post #6 of 16 Old 09-17-2005, 09:41 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Okay, that makes perfect sense. The hook will be a good deal for you. Unless you want to use the rear hatch hasp like one guy did for a tow point.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 16 Old 09-17-2005, 09:44 PM
10achik
I ate what?
10achik's Avatar
Hunter
(10 character limit)
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #8 of 16 Old 09-17-2005, 09:45 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
His reasoning was that it did work and that it was only done once and in an emergency.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #9 of 16 Old 09-17-2005, 10:07 PM Thread Starter
CinciSurWJ
CinciSurWJ's Avatar
Hunter
I got tow hook in the front, I hesitated to get one for the rear. (Do we really need one)
But since it is a used one and got good deal on it, I ended up in getting one.
- suresh
post #10 of 16 Old 09-17-2005, 11:56 PM
JCDubya
2009 WK
JCDubya is offline
post #11 of 16 Old 09-18-2005, 04:17 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Unless you have a rear tow hitch or tow point, a lot of parks or ORV areas won't let you in.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #12 of 16 Old 09-18-2005, 06:23 AM Thread Starter
CinciSurWJ
CinciSurWJ's Avatar
Originally Posted by JCDubya
Thanks Dubya !!
I looked at it before, but the diagram does not explain how the braces go.
post #13 of 16 Old 09-18-2005, 07:53 AM
JCDubya
2009 WK
It bolts on the drivers side of the gas tank skid. If you get under there and take a look, it should be pretty self explanatory.
JCDubya is offline
post #14 of 16 Old 09-18-2005, 06:37 PM Thread Starter
CinciSurWJ
CinciSurWJ's Avatar
Were you able to take some pics.
post #15 of 16 Old 09-18-2005, 06:42 PM Thread Starter
CinciSurWJ
CinciSurWJ's Avatar
Yeah, I figured out this part. The Kit came with a Tow hook which is already attached to a bracket, this is the one goes along the drivers side of the gas tank skid.
But the kit also came with a brace ( a rod like ), one side need to be bolt on the tow hook bracket, but couldn't figure where the other end goes. There is a U-bolt which came with the kit, no idea where this goes in the frame.
front tow hook install RMFK13 ZJ Grand Cherokee Forum 16 09-27-2009 02:48 PM
Zj tow hook install LoCo_ZJ ZJ Grand Cherokee Forum 15 09-21-2009 07:04 PM
WJ tow hook install highryder08 ZJ Grand Cherokee Forum 3 12-25-2007 09:24 PM
Tow Hook install? mar11902 ZJ Grand Cherokee Forum 13 11-06-2007 04:33 AM
WJ Tow Hook Install (pics) 10achik ZJ Grand Cherokee Forum 2 08-29-2005 09:18 PM
