WJ rear suspension clunking - JeepForum.com
post #1 of 12 Old 11-25-2008, 08:57 AM Thread Starter
aagill225
I have a '99 WJ 4.7L laredo. I get this clunking from the rear suspension. It happens over everything, pot holes, speed bumps, the cracks in the road. I repalaced the ball joint on the rear upper control arm and it seemed to releave some of the problem but it still excists.
aagill225 is offline
post #2 of 12 Old 11-25-2008, 09:05 AM
WVWalker
I had a clunking in mine. I replaced the shocks and now its fine.
WVWalker is offline
post #3 of 12 Old 11-25-2008, 09:32 AM
BlackShuck
Is your Jeep stock? Or have you changed suspension parts?
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline
post #4 of 12 Old 11-25-2008, 11:13 AM
MeWJWifeZJ
Mine had a worn shock bushing. When the shocks were replaced it went away, now it's come back after about 1500 miles after having the shocks re-torqued.
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #5 of 12 Old 11-25-2008, 11:57 AM
lamar2626
i have the same problem.. i just got the 4" IRO kit with the Doetsch9000 shocks and it still does it.. any ideas anyone?
lamar2626 is offline
post #6 of 12 Old 11-25-2008, 12:37 PM
BransJeep
take your stock shocks, get the bar pins out of them by burning the bushing, cool them off and clean them, then press them into your shock bushings with a vice, worked for me on my black diamonds. They had horrible clunk, now its gone!
-Brandon
4.0, 42re, 242
4.5 inch lift, front Ironman 4x4 adjustable CA's
RB1 and full J&L audio setup
Rola roof rack
BransJeep is offline
post #7 of 12 Old 11-25-2008, 01:00 PM
the88thpianoman
2003 WJ
You need the KOR shock mount kit, unless you still have your stock shocks and can pull the parts out of there. Personally, I just opted for Kevin's kit since that also includes new hardware. But either way, that will take care of it.
the88thpianoman is offline
post #8 of 12 Old 01-24-2009, 09:54 AM
sk0073
I see this is an old thread but i've had the same ongoing problem. I put on skyjackers budget boost (2 inch w/hyrdos) had the clunking noise so i bought the KOR kit and still clunking but it looks like the top shock mount is cracked and is able to move freely. Im guessing this is the problem, and will it just take a simple weld?
sk0073 is offline
post #9 of 12 Old 01-24-2009, 09:59 AM
311LJ
311Popo
311LJ's Avatar
if the bushings sizes and stuff are wrong some people have been known to put some washers in there to tighten that up. I pulled the stock sleeves out of my stock shock bushings and slid them into my mx6's.. no noise
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #10 of 12 Old 01-24-2009, 10:07 AM
xJoshxx
2012 WK
ive done that use'd thick washers on each side keeps the bushing from poping out
xJoshxx is offline
post #11 of 12 Old 01-24-2009, 10:21 AM
OFFRDWJ
What is the KOR kit exactly can it be home made ?
I have clunking also and I just ignore it now ....
But I have a feeling its my rear shocks. And I too have a bb...
OFFRDWJ is offline
post #12 of 12 Old 01-24-2009, 10:39 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Probably can't be homemade, maybe. Idk but it 18 bucks. Here is a link. It is at the top of the list of stuff. http://www.kevinsoffroad.com/wj/wj_25kit.html
Brian
WJ, WK, CJ5
GraKee99 is offline
Suspension clunking and crunching sounds after lift sk0073 ZJ Grand Cherokee Forum 12 11-18-2008 11:21 AM
Clunking/Knocking from front end suspension Clifford97GC ZJ Grand Cherokee Forum 5 08-31-2008 07:32 AM
Clunking back suspension? Grazsrootz ZJ Grand Cherokee Forum 8 07-22-2007 11:21 PM
Suspension Clunking 101: found something unlikely HighLonesome ZJ Grand Cherokee Forum 6 01-06-2007 04:27 PM
Clunking Sound - Rear Right Suspension guns2323 ZJ Grand Cherokee Forum 3 06-08-2005 08:54 AM
