WJ Rear bumper mock up/build - JeepForum.com
post #1 of 47 Old 03-30-2009, 04:05 PM Thread Starter
AgitatedPancake
WJ Rear bumper build *UPDATED 4/11/09*
Alright so I'm tinkering with a little mockup for the rear bumper right now, tell me what you guys think! Any input welcome.
I know its hard to see whats going on because of the colors of the cardboard, but yeah.
So I have it sticking out to protect the fender,
In the second picture, the part that says BES will be on the same plane as the white/blue that goes down to the bottom of the frame rail.
Here you can see the plane differences. I'm not sure how much I like that look, but I just threw it together a couple mins ago. This is where I need input!
I haven't welded the remnants of that peice to the floorboard so its pushing out, but here you can see how they will be for the final assembly.
For frame attatchments I'm looking at getting some 4x4 angle iron or 4x4 box tube (and cutting it out), so the side of the frame rails have material to weld supports to for the sides.
Example: Go from the angle iron/box out to the sides right on the bottom of the floorboards with 1" square tubing or something.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #2 of 47 Old 03-30-2009, 04:14 PM
CaribouLouWJ
2007 WK
mmmmm, Pizza
I like it so far...
2007 WK Overland
5.7 Hemi, 18% tint, baby seats
2000 F350 PSD CC LB
2001.5 B5S4 500awhp gutted track car
2002 WJ Limited
4.7 HO, 6.5" LA, 37's, JK 44's SOLD
CaribouLouWJ is offline
post #3 of 47 Old 03-30-2009, 04:14 PM Thread Starter
AgitatedPancake
$5 pizza's and propel water =D
Build Thread:
post #4 of 47 Old 03-30-2009, 04:17 PM
CaribouLouWJ
2007 WK
Stop, I'm hungry, lol
2007 WK Overland
2000 F350 PSD CC LB
2002 WJ Limited
post #5 of 47 Old 03-30-2009, 04:25 PM
CMARJEEP
CMARJEEP's Avatar
Looks nice but I don't think cardboard is going to hold up very well.
CMARJEEP is offline
post #6 of 47 Old 03-30-2009, 04:45 PM
lakailimited06
AP, im sure you've seen this guys bumpers on MC but i figured id show you maybe it'll give you some more ideas i think they looks good..
http://home.comcast.net/~weghorst/WJ/wjBumpers/
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #7 of 47 Old 03-30-2009, 05:01 PM Thread Starter
AgitatedPancake
That bumper does look well designed, but I chopped alot of stuff out under the rear taillights AND have the gas tank raised which really change the lines of the bumper so I can't apply alot of the stuff from that bumper =/. My bumper is going to be probably half as tall as his, isn't going to bee hanging down much AT ALL (about 4" below bottom of tailgate)
Build Thread:
post #8 of 47 Old 03-30-2009, 05:21 PM
lakailimited06
true sounds like your all about performance and clearance, keep us updated i want to see pics
99WJ 4.0
post #9 of 47 Old 03-31-2009, 02:10 PM Thread Starter
AgitatedPancake
Alright took another look today, and decided things would be much simpler if I chopped up to the floorboards instead of trying to cut all those angles. I'm much happier with the cutting, and its making my mounting solutions easier on me.
New cut:
I put the gas tank skid up to check clearance back there. Its also nice because the bottom of the frame rails are in the same plane as that sheetmetal still hanging off the back, I am literally gunan end up with my mounts going straight back off the framerails into the bottom plate of the bumper.
And now I'm thinking about cutting all of that sheetmetal out that I can, I can gain alot of space in here for storage if I bring the inside of the bumper as close to the gas tank as I can. Yeah, I still want to do a storage bumper, we will see if I can pull it off clean or not.
Build Thread:
post #10 of 47 Old 03-31-2009, 02:34 PM
skain8
skain8's Avatar
Looks good. I'm always a fan of homebrew builds.
The floorboard cuts should really cut down on the build. Keep us posted.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #11 of 47 Old 04-01-2009, 03:10 AM
sandman
nice!!!! i like that its built for clearance.
1993 Jeep ZJ. 4.0
sandman is offline
post #12 of 47 Old 04-05-2009, 06:31 PM Thread Starter
AgitatedPancake
Alright got some plate and started the fab...here are some pics for ya guys.
1/4" plate on the bottom and outside of frame rails.
It will use all the bolts that the hitch and gas tank use. It may be a PITA to install as it and the gas tank have to go at the same time but oh well.
I got my bends started on the rear peice...
And the potential storage area.
It will end up with a little less than this
finish welding the frame rail "L"s.
I got pissed at my welder. I cleaned it all up with a wire wheel on the grinder, welded most of it up then the last 2-3 welds all got bad porosity...I cant figure out why. With the first one I thought it was because of wind so I shut my work area up, then the next one did it as well. I can hear and feel the gas coming out of the nozzle, and I cranked the output up to like 27cfh with no change. This has happened once before and went away on its own. I'm running a miller 180, 220v with .025 wire (I know a little thin for heavy metal like this.) and co2/argon mix.
Build Thread:
post #13 of 47 Old 04-05-2009, 07:34 PM
dmolaver15
the bumper looks sick so far, i think i'll be looking back to this thread when it's time to build one for mine
PS Agitated: you have a PM
04 WJ 4.0
6.5" IRO Front and Rear Longarms
Soft 8's, 285/75/16 BFG Mall Terrains
Super 44 with 3" Side Dump
Dana 44a, 4.56's
My Build Thread:
dmolaver15 is offline
post #14 of 47 Old 04-05-2009, 07:53 PM Thread Starter
AgitatedPancake
Thanks man, PM replied!
Build Thread:
post #15 of 47 Old 04-06-2009, 05:37 PM Thread Starter
AgitatedPancake
Got some more done today
I had to extend my L's, I didn't like how close the bumper was to the body.
Back side
around 4.5" to the bottom of the tailgate. I wanted it to stick out to where if I backed into something or got rammed my tailgate wouldn't take the hit.
In the storage area, I cut out a part that was intrusive and welded in a peice of plate. The area is about 42" wide, 7-8" deep and 4" tall...I can carry pretty much whatever I want back here (though I don't have the hitch in yet...)
Build Thread:
Front Bumper Build Inavacuum ZJ Grand Cherokee Forum 7 11-02-2011 04:40 PM
My Stinger Bumper Build (PICS) Art101 ZJ Grand Cherokee Forum 17 02-10-2009 01:19 AM
Want to build a bumper what do you think ? CyberManiaK ZJ Grand Cherokee Forum 28 04-14-2008 01:18 PM
Beginning of WJ bumper build...56k=NO (first fab job!) AgitatedPancake ZJ Grand Cherokee Forum 79 02-16-2007 09:49 PM
Front Bumper mock up (pictures) EMTimZJ ZJ Grand Cherokee Forum 22 09-26-2005 11:16 PM
