Wj power steering pressure hose leaking - JeepForum.com
post #1 of 13 Old 03-15-2009, 10:11 PM Thread Starter
Neongirl4ever
I have had a small leak for awhile. I cleaned up the motor with engine degreaser to see if i could find the leak. At first I thought it was the actual pump that was leaking. So i purchased a new pump and installed it. Leak of course came back and was ten times worse. Once again i cleaned everything up and checked again. Of course it had to be the high pressure hose. So i went down to the dealer. They told me that the hose is on National back order and they dont see this hose coming in till June. WTF? So I decided to stop by autozone, oreillys, advance, and Napa. Nobody carrys a aftermarket part for this. I went down to Custom Hose, a local shop, and even they cant help me. The only thing they said they are missing is that actual fitting that goes into the pump. I feel I have exhausted all of my resources. Does anyone have any idea on what I should do now. This jeep is my daily driver. I have no other car to borrow or anything. Im going thru a quart a day of power steering fluid. Its now been a week with this major leak and good thing I have a warranty on my new pump cause im about to blow this one!
2002 Black WJ 4.7L H.O
Quadra Drive
Is repairing considered a modification?
Neongirl4ever is offline
post #2 of 13 Old 03-15-2009, 10:49 PM
elmer_fud
maybe you can find a used hose. Look for someone parting out an entire jeep or check the junkyards
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 13 Old 03-15-2009, 10:57 PM
DothanJeep
Ah, I had one I would have given you for free, I ended up giving it to another member, Sorry to hear ... I bought a new one for 30.00 from a local parts store.
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline
post #4 of 13 Old 03-16-2009, 08:32 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I have one from a totaled WJ, PM me if you're interested.
Its a newer replacement part with not even 3k miles on it. Its still clean.
Part # is 5019708AD.
Wheelin98TJ is offline
post #5 of 13 Old 03-16-2009, 12:50 PM Thread Starter
Neongirl4ever
Thanks for all the feed back. I will get back to you wheelin98tj if i need it. Im going to call a few other dealers and see what they say. Thanks though.
Quadra Drive
post #6 of 13 Old 07-08-2009, 12:21 AM
TyBauz
What tool for power steering pressure line?
I ordered a power steering pressure line hose but don't know how I am going to get the existing one off the pump. Has anyone done this? What tools will I need? I have tried vice grips but they slip. I can't seem to get a wrench on it either. Any help would be greatly appreciated. Thanks!
TyBauz is offline
post #7 of 13 Old 07-08-2009, 12:37 AM
jasn1981
I did mine about a month ago... Just took off the radiator upper hoze to get more room and used a cresent wrench for the top and bottom.
2002 WJ 4.7L V8 W/Selec-Trak: 2" OME Lift W/32's
Gibson Exaust, K&N Cold air intake
jasn1981 is offline
post #8 of 13 Old 07-08-2009, 12:38 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
When I needed this hose, there were no auto parts stores in the Chicagoland area that sold them. Dealer only.
Where is it leaking exactly? The rubber? the fitting into the top of the pump?
How do the o-rings look?
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #9 of 13 Old 07-13-2009, 03:47 PM
TyBauz
Leak Location
It is leaking at the hose at the top of the pump. I suspect a bad O ring inside the hose; therefore I am just replacing the entire hose anyway. You can order the hose from oreilly auto parts online. The part # is 92099 and it is $30.99. I added some extra stuff to get free shipping.
TyBauz is offline
post #10 of 13 Old 07-13-2009, 03:48 PM
TyBauz
I will try that. Thank you!
TyBauz is offline
post #11 of 13 Old 07-13-2009, 08:00 PM
Turbonut
That's not for the hydraulic fan that was factory starting 2001 with the 4.7.
#92099:
JEEP GRAND CHEROKEE LAREDO (1999 - 2000)
JEEP GRAND CHEROKEE LIMITED (1999 - 2000)
Turbonut is offline
post #12 of 13 Old 12-21-2012, 06:33 PM
tjude
2000 WJ power steering hose
Thanks for these notes. I have a 2000 WJ 4.0 six. Hose is leaking and I just bought a replacement at O'Reilly. Managed to get the top nut off easily' but can't seem to be able to get at the lower. I can get the crescent wrench around the nut, but there's only a few degrees I can use. Even if I cut the hose and use a ratchet, I still need to get the new hose on.
Tried to remove the air box, but I can't see more than two bolts. Removing it might give me more room.
Any guidance? I'm going to see if I can get a line wrench tomorrow, but I can't see that it will be any better.
Thanks.
tjude is offline
post #13 of 13 Old 01-26-2014, 02:51 PM
JeepNewb1
Lower connect or leak
So I replaced the high pressure power steering hose and it was kind of a pain in the ars to get the threads threaded. When I finally got everything together and it seemed fine for about a week and started to lose fuid. I think it is leaking where the hose snaps into the bottom fitting at the fan. Is there a trick to snap the hose into the fitting? It seems in there tight but I haven't gone under to see if its leaking. Could it be a tone of air? I put 2 quarts of mopar power stearing fluid it. While I had it apart I turned the steering lock to lock until no more fluid came out. How many quarts does it take if it is mostly drained?
JeepNewb1 is offline
Power steering pressure hose mtcox WJ Grand Cherokee Forum 12 06-14-2010 04:24 PM
Power Steering Pressure Hose 94 GC 4x4_billy ZJ Grand Cherokee Forum 5 01-25-2010 01:25 PM
Power Steering Pressure Hose change unabashedpraise ZJ Grand Cherokee Forum 3 03-05-2009 10:30 AM
help with power steering pressure hose lil_sol ZJ Grand Cherokee Forum 8 05-10-2008 04:48 PM
Help me with my leaking power steering hose frisco ZJ Grand Cherokee Forum 5 09-12-2006 07:05 PM
