WJ Power Steering Fluid Radiator Enhancement - JeepForum.com
post #1 of 34 Old 03-25-2006, 01:27 PM Thread Starter
nedsud
Last Summer when on a trail ride and after ascending a rock slide, my power steering hose blewout. It over heated from the rock action. since it blew out again so I replaced the hose again. I looked at the stock fluid radiator and it is tiny and not in the flow of air.
I have been thinking about adding a larger radiator for the power steering.
Has anyone done this?
Ned
http://jeepgrandcherokeelimited.blogspot.com/ for jeep WJ pics
nedsud is offline
post #2 of 34 Old 03-25-2006, 02:47 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Iím not sure that I follow you. Are you interested in a bigger radiator, if so then get a three row rad. But it almost sounds like you are interested in a power steering fluid heat exchanger?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 34 Old 06-08-2006, 09:23 PM Thread Starter
nedsud
on my wj, there is this small radiator about 3 inches wide and 9 inches tall. it is connected to the power steering fluid line. it exists in front of the radiator, but off to the side. the way it is positioned, it looks like there is little air flow going through it. so i was going to replace it with a 10 x 10 or something like that. is this clear?
WJ photos -
2000 WJ Limited, V8, rear limited slip, BFG AT KO, 2 inch BB, BMG Roof Rack, CB radio, Fire Ext., Compressor, front tow hooks, rear recovery shackle
nedsud is offline
post #4 of 34 Old 06-09-2006, 06:30 AM
greasefingers
1994 ZJ
Is it stock for WJs to have a power steering cooler, or is this something that you added?
Cheers Steve
post #5 of 34 Old 06-09-2006, 07:34 AM Thread Starter
nedsud
I dont know. I did not add it. I am not the orginal owner.
WJ photos -
nedsud is offline
post #6 of 34 Old 06-09-2006, 08:06 AM
Double E
Double E's Avatar
I guess I need to look more closely but on mine, I assumed that was the tranny fluid cooler.
I had a similar thing happen to my PS hose while towing the heavy old boat. The hose popped off & sprayed the header putting out a huge cloud of thick white smoke. (Great show for traffic.)
The pressure had just caused the hose to pop off the fitting. Did your hose actually rupture?
Anyway, I had a bottle of fluid nearby and a screw-type SS hose clamp and was on my way.
If your hose ruptured, I'm going to get some braided stuff soon for mine.
Are you certain it's the PS system's fluid cooler you're looking at?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #7 of 34 Old 06-09-2006, 08:14 AM
greasefingers
1994 ZJ
Yea power steering coolers are not that common (usually an add-on). He probably is looking at his external tranny cooler, which comes with the towing package.
Cheers Steve
post #8 of 34 Old 06-09-2006, 08:15 AM
rm2001wj
rm2001wj's Avatar
The tranny cooler for WJs are built into the engine coolant radiator. Power steering fluid radiator is a small separate unit.
rm2001wj is offline
post #9 of 34 Old 06-09-2006, 09:23 AM
greasefingers
1994 ZJ
Every automatic transmission has a tranny cooler built into the radiator. If one sees an external cooler mounted in front of the A/C condenser, then 99.86 % of the time it is a second externally mounted tranny cooler. These external mounted tranny coolers are almost always supplied with towing packages.
If in doubt, follow the lines.
Cheers Steve
post #10 of 34 Old 06-21-2006, 08:58 AM Thread Starter
nedsud
I have followed the lines and this small cooler is about 4 inches wide and 7 inches tall and connects to the power steering.
WJ photos -
nedsud is offline
post #11 of 34 Old 06-21-2006, 10:51 AM
micifus
Original GC'er
micifus's Avatar
pics pics pics pics
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #12 of 34 Old 06-21-2006, 01:04 PM
Handed
It probably is a power steering cooler
Also for those of you in the know, the tow package comes with an external tranny cooler and not a power steering cooler, is that correct...although the power steering cooler definelty would help.
04 Grand Cherokee
Handed is offline
post #13 of 34 Old 06-21-2006, 01:09 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
I'm not sure about WJs but ZJ has no external power steering coolers. I've seen some folks add external tranny cooler to power steering system as a mod though
zaq123 is offline
post #14 of 34 Old 06-21-2006, 01:11 PM
Meerkat
Don't know about WJ's (other than it stands for Woosie Jeep)
However, perhaps this bit of ZJ tech can be modified to work for you.
On the 5.2 liter ZJ, the transmission cooler is mounted on the passenger side in front of the radiator. On the 4.0 Liter ZJ, the transmission cooler is mounted on the driver's side in front of the radiator. The two units have different numbers because of the way they are plumbed. It is a fairly easy and common mod to get a 4.0 cooler and adapt it to the power steering unit, significantly decreasing PS fluid temperature.
HTH
BTW, just kidding about the woosie part...
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #15 of 34 Old 06-21-2006, 02:06 PM
greasefingers
1994 ZJ
I am still trying to figure out why a power steering pump cooler would ever be needed
Cheers Steve
Power steering fluid to use? kontrast ZJ Grand Cherokee Forum 2 12-27-2009 09:18 PM
What power steering fluid can I use? ct-snoman ZJ Grand Cherokee Forum 12 04-28-2009 11:37 AM
Power Steering Fluid shashank ZJ Grand Cherokee Forum 10 10-26-2007 05:46 AM
Power Steering fluid in '01 GC? shortlid ZJ Grand Cherokee Forum 10 11-18-2006 09:25 AM
Power steering fluid miteus ZJ Grand Cherokee Forum 5 10-25-2006 04:15 PM
