WJ passenger side window has fallen and can't get up! - JeepForum.com
post #1 of 11 Old 06-11-2009, 06:27 PM Thread Starter
crazyjmk
2002 WJ Laredo...SO the window dropped down inside the door and I fished it out with a needle nose pliers and duct tapped it up as we were 500 miles from home. WHen you hit the switch it makes some great grinding noises and it sounds like stuff in there is all rattling around inside the door. Thoughts on what I need to order to replace whatever is broken prior to taking it apart? I live in a area with limited access to parts without a 2-3 day wait and need the thing for a daily driver.
Thanks in advance!
J
crazyjmk is offline
post #2 of 11 Old 06-11-2009, 06:37 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Sounds like a window drive unit failure. You may have to order a complete unit, many of those power window units are not repairable.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 11 Old 06-11-2009, 06:48 PM
99avant
Window Regulator. Common problem, documented fix.
Do a quick search for some options.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #4 of 11 Old 06-11-2009, 06:51 PM
skain8
skain8's Avatar
Yeah, you have to buy the complete window regulator as a single replacement unit. However, I used a wire hanger fix. Was free and stronger than new! Most time consuming part was taking all the panels, etc.. apart to get to the regulator. Search it.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #5 of 11 Old 06-11-2009, 07:20 PM
gmp211
So call LifeAlert!!!
But seriously...You probably need a new motor.
2002 WJ - Forest Green
gmp211 is offline
post #6 of 11 Old 06-11-2009, 07:23 PM
skain8
skain8's Avatar
Motor is fine; the regulator cable snapped off it's plastic anchor.
skain8 is offline
post #7 of 11 Old 06-11-2009, 07:28 PM
bikecop
check out Amazon.com thats where i got mine
http://www.amazon.com/Dorman-Solutio...tive&carId=004
bikecop is offline
post #8 of 11 Old 06-11-2009, 07:55 PM
crashcraddock
Oreillys, or advance, or any auto parts store. They will all price match, maybe $5 more than online after shipping, plus you'll get it now.
crashcraddock is offline
post #9 of 11 Old 06-11-2009, 10:40 PM
YJDuff
I got both of mine off ebay.
"Life is a garden, dig it!"
02' 4.0 WJ
2" bb lift
245/75/16 Goodyear MT/R
Rusty's Tow Hooks
YJDuff is offline
post #10 of 11 Old 08-23-2009, 09:55 PM
tommy_chunk
my cheap fix was to pull the window up and clamp off the cable with vise grips. It got us by until I could locate a new regulator. I guess it would work forever unless you want the window down again.
tommy_chunk is offline
post #11 of 11 Old 08-23-2009, 10:09 PM
volvite
window motor with regulator with lifetime warranty at the autozone for like 70
volvite is offline
07 wk passenger side window issues 07JGCL WK Grand Cherokee & XK Commander Forum 3 01-04-2009 08:55 PM
Passenger side power window does not work rrich49132 ZJ Grand Cherokee Forum 2 12-16-2008 12:43 PM
Passenger side window problems. TheDude584 ZJ Grand Cherokee Forum 2 03-30-2007 04:24 PM
problem with the passenger side window Jayhawk077 ZJ Grand Cherokee Forum 1 06-22-2006 04:53 PM
Passenger Side Window SideTrack ZJ Grand Cherokee Forum 1 11-21-2005 12:35 AM
