WJ passenger side knuckle on ZJ? - JeepForum.com
post #1 of 4 Old 03-12-2012, 09:48 AM Thread Starter
TurboTPI
Can a WJ steering knuckle be used on a ZJ? I was looking at the wifes the other day and it looks like a better setup than my ZJ steering. heres a pic of what im talking about.
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #2 of 4 Old 03-12-2012, 02:15 PM
KingtheZJ
no. search "WJ knuckle swap"
you need to use WJ brakes, weld on a spacer, etc
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 4 Old 03-12-2012, 11:59 PM
amremt408
WJ steering knuckles can be used on a ZJ. but it is not as simple as just using the knuckle itself. you must use WJ brake calipers/pads/rotors as well as ball joints, a spacer, bearing hubs i believe and possibly a few odds and ends. it is a good upgrade that a lot of ZJ owners with lifts or bigger tires run to improve stopping performance; take a look at the brake calipers side by side and you'll see how much bigger the WJ set up is than the ZJ.
5.9 ZJ... 4.5" Rubicon Express short arms. Bridgetone REVO 2's... 265/75/16.
2004 WJ... OME HD coils, Bilsteins shocks, JKS adj track bar, MOOG SS, ADDCO rear sway bar with ext., Bridgestone REVO 265/70/17.
amremt408 is offline
post #4 of 4 Old 03-13-2012, 12:37 PM
JohnnyZJ
you will need to upgrade to the WJ brake booster as well, otherwise those bigger brakes won't do any difference.
07' JKUR rollin on 35s
JohnnyZJ is offline
Driver side 1 inch higher than passenger side Joe-Joe ZJ Grand Cherokee Forum 1 06-04-2010 11:19 AM
98 ZJ Passenger Steering Knuckle Issue doogie1303 ZJ Grand Cherokee Forum 4 05-17-2009 03:58 PM
94 GC - Worn out Knuckle on Pass. Side Tie Rod magik20 ZJ Grand Cherokee Forum 5 11-29-2008 10:43 AM
99 Grand Cherokee Ltd Heat on passenger side cold on Drivers side. WHATS WRONG?? nosguy ZJ Grand Cherokee Forum 9 12-30-2007 09:15 AM
Driver-side steering knuckle turk ZJ Grand Cherokee Forum 2 07-04-2006 12:24 PM
