WJ Overheating in Traffic - JeepForum.com
post #1 of 14 Old 07-19-2007, 07:25 PM Thread Starter
safarimike
My brothers Jeep - 2001 WJ 4.0
Says it overheats in traffic, highway driving its fine. Started it up tonight, let it idle in park with a/c on. Gets to to 210, climbs pretty quick (less than 5 minutes) to just under 260, which is when I turned it off. Letting it run I kept checking the cooling fan, fan never came on. So, I guess thats the problem, anybody have any ideas why its not?
I tried to find a fuse for it, but its a weird looking thing, doesn't look like a normal fuse or relay. Its a 40 amp, and there are other 40 amps under there, so I am going to swap one of em and see what happens once engine cools down.
1999 Jeep Wrangler Sport
safarimike is offline
post #2 of 14 Old 07-19-2007, 07:27 PM
djdoug99
I think the fan relay is a common fix to the fan not turning on problem. The relay is under the right headlight, or left. I forget.
djdoug99 is offline
post #3 of 14 Old 07-19-2007, 07:44 PM
Redbob
A quick check is to turn on the air conditioning; if the fan doesn't come on in less than a minute, there's a fan problem.
Redbob is offline
post #4 of 14 Old 07-19-2007, 07:46 PM
djdoug99
Here is a link that may be helpful. Scroll down to the fan relay portion
http://rigs.corequipment.com/cebby_W...ooling.htm#top
djdoug99 is offline
post #5 of 14 Old 07-19-2007, 07:51 PM Thread Starter
safarimike
Swapped the blower motor fuse (although it doesn't look like a fuse) for the 4.0 cooling fan fuse. With cooling fan fuse in blower motor fuse, blower motor still worked. Checked connection, its plugged in, appears to be no signs of wire damage from what I can tell. Check engine light is on now.
I guess the best bet would be to get a test light on the connector and see if the fan is getting the supplied power and ground.
post #6 of 14 Old 07-19-2007, 07:54 PM
djdoug99
get the codes and use a 12V source for the fan.
djdoug99 is offline
post #7 of 14 Old 07-20-2007, 08:54 PM Thread Starter
safarimike
I didn't get a chance to work on it today, but I am gonna try to swap relays and see if thats the cause. Can I just swap relays with one of the ones up top in the electrical box?
post #8 of 14 Old 07-20-2007, 08:58 PM Thread Starter
safarimike
just read about cutting the access hole for the relay, I will go with the test light idea first before i start taking stuff apart.
post #9 of 14 Old 07-20-2007, 09:59 PM
Dodge,Jeep Tech
wow this is fun hehe seeing all the different things people say and do.
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
Dodge,Jeep Tech is offline
post #10 of 14 Old 07-20-2007, 11:25 PM
skain8
skain8's Avatar
well, what's your suggestion?
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #11 of 14 Old 07-22-2007, 04:47 PM Thread Starter
safarimike
put a test light on the connector. looks like a constant ground at the connector, and the fan is supplied a power. with a/c on, let it run up above 210,but below 260, never got one power signal from the wire. so i am guessing its the relay?
post #12 of 14 Old 07-22-2007, 05:00 PM
lma1973
260 is way too high...never let it get that hot-turn it off first if you have to!!!
2005 Jeep GCL Hemi
Gibson 3" catback exhaust
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #13 of 14 Old 07-22-2007, 10:35 PM
simidrm
use a jumper wire to test fan if it works then the problem is the fan relay its locate behind the head light on the passenger side frame.
you have to pull both headlights grill-front bumper cover and plastic grill support.
About a 3hr job most shops charge 180-200 to fix relay was 60.00 at autozone
simidrm is offline
post #14 of 14 Old 07-22-2007, 10:59 PM
Cebby
Or cut the hole like in my writeup and future changes take 5 minutes. I'm on my 4th fan relay. BTW, my "5-Star" dealer charged me 3 hours of labor to cut the hole beneath my headlamp. I discovered this when the relay they installed died.
BTW, testing the fan is a good first step - the connector to it is on the side of the shroud - it uses one of those red clips to keep it together. Polarity doesn't matter for testing - it should fire right up when put to 12 volts.
2000 WJ Laredo 4.0 4x4 Taupe Frost - Clayton LA Front/Rear | IRO 3" Springs + 3/4" KOR | Bilstein Shocks | JKS Discos/Trackbar/Draglink & Tierod | Dual KOR Stabs | Spidertrax Spacers | 265/70R17 Duratrac's on JK 17's | Black Magic Brakes w/Centric Rotors | Akebono Calipers | Griffin Rad | K&N Drop in | Magnaflow Cat & Muffler shorty setup | Diehard Platinum (Odyssey) | RB1-NAV-Sirius-Chg-iPod | OEM Tow Hooks F/R
Cebby is offline
5.2L Overheating on stop and go traffic. BayjiRaider ZJ Grand Cherokee Forum 25 08-14-2011 11:28 PM
99 Grand Cherokee overheating when in heavy traffic, with or w/o A/C on roxygirl25 ZJ Grand Cherokee Forum 14 07-21-2009 11:36 AM
GC Stalls out in traffic, help! alan8228 WK Grand Cherokee & XK Commander Forum 7 05-19-2009 12:01 PM
anyone use sirius traffic and what is it? crod WK Grand Cherokee & XK Commander Forum 6 12-28-2007 05:25 PM
2000 JGC overheating when sitting in traffic. Joey P. ZJ Grand Cherokee Forum 60 07-26-2006 12:03 PM
