WJ mystery warning beeps - JeepForum.com
 1Likes
  • 1 Post By STL_WJ
post #1 of 15 Old 08-17-2009, 10:21 AM Thread Starter
mdsummerfield
THis has me stumped and i haven't found any defining answers on the forums. I have an 01 WJ. Yesterday after about a 4 hour drive i noticed that upon acceleration I would receive a set of warning beeps of some sort, but without any sort of light or console definition. The beeps come in two sets of three, Beep Beep Beep, pause, Beep Beep Beep. All of my gauges are reading normal on the dash, and i receive no idiot lights or messages on the console. Anyone have any ideas?
mdsummerfield is offline
post #2 of 15 Old 08-17-2009, 10:29 AM
Double E
Double E's Avatar
Anything on the overhead display?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 15 Old 08-17-2009, 10:31 AM Thread Starter
mdsummerfield
Nothing on the overhead. Nothing on the dash. Just the beeps. She drives the same...doesn't feel like it's bogging down or a problem anywhere.
post #4 of 15 Old 08-17-2009, 11:32 AM
iluvtruenos
Sounds like a door/liftgate open warning.
Maybe it was intermittent, and opened itself momentarily not long enough to illuminate the display.
Open the driver's door while moving in D, it should make the same beeps.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #5 of 15 Old 08-17-2009, 01:09 PM
Double E
Double E's Avatar
luvtrue makes good sense here....is it at least the same warning sound?
Can you do an extended acceleration test to see if an overhead message finally displays?
Just for giggles, what information is displayed on the overhead on a normal basis?
Double E is offline
post #6 of 15 Old 08-17-2009, 02:03 PM
Jey109
check your coolant, your oil pressure, your doors, liftgate, etc, i get the sound at least 2 times a week from anyone of those, it's something you'll find it....or it'll find you, thats just how they are lol.
Jey109 is offline
post #7 of 15 Old 08-17-2009, 02:32 PM
journey50
2014 WK
on my 02 limited if i forget to turn the directional off it will beep a few times after a few minutes... drove me crazy trying to figure out what the problem was..till i looked at cluster and seen the left signal light on..
journey50 is offline
post #8 of 15 Old 08-17-2009, 04:33 PM
pmeguy
Could it be your "service interval" beeping? That happened to me and it took me a few days to figure it out. A quick reset and I was good to go.
1999 WJ Ltd 4.7 QD
1991 YJ 4.0 Auto SOLD
1992 YJ 4.0 5spd SOLD
1998 TJ 4.0 5spd SOLD
1950 CJ2A SOLD
pmeguy is offline
post #9 of 15 Old 08-17-2009, 05:56 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Check your liftgate sensor. I get the exact same thing if my liftgate is not secured tight enough. It happened after I got rearended and messed up the liftgate. The display will not show anything, just give the 3 beeps.
WiCkeDuDe is offline
post #10 of 15 Old 08-18-2009, 11:19 AM
thilinaw
Junior Member
my 00 WJ gave me that same beep for being out of windshield washer fluid...out of all things....so I wouldn't bet against it being something small like that.....hope that you figure it out though....
thilinaw is offline
post #11 of 15 Old 08-18-2009, 12:53 PM Thread Starter
mdsummerfield
Thank you all for your WJ wisdom! Oddly enough i have not been able to recreate the problem once i've posted it. (just my luck!) So for now i'm going to chaulk it up to either an electronic goblin, or my liftgate (as i have open and closed it since). All fluids are fine, all pressures are fine. Until i can get it to beep at me again, i'm in a holding pattern. FYI Double E...my overhead predominantly displays temperature and direction.
Again, i appreciate all the feedback!
post #12 of 15 Old 08-18-2009, 06:07 PM
adgjqetuo
adgjqetuo's Avatar
Do you have the tire pressure sensors? I know that if you drive and the tires warm up and exceed 45 PSI (I think) it will beep at you. If it does it again, go to the tire monitor screen and see if any of the tire readings are blinking.
04 Jeep grand Cherokee Overland - Sold
98 Jeep Grand Cherokee Laredo SE - Sold
adgjqetuo is offline
post #13 of 15 Old 08-18-2009, 06:42 PM
Mikeg175
I'll jump in say go with the liftgate , I had the same occurrence and it was just that my liftgate was just off a little . It was freaking me out , I'd be driving along then beep beep beep , I was able to catch the overhead and saw it said liftgate open , so I cleaned everything and havent had it since .
Mikeg175 is offline
post #14 of 15 Old 08-18-2009, 08:19 PM
MarkPMB
I've noticed I have left the turn signal on several times after getting on the interstate.
After a short distance it will beep a few times.
MarkPMB is offline
post #15 of 15 Old 01-03-2014, 02:16 PM
STL_WJ
I know this is an old forum sorry but mine has been doing the mysterious beeping for a few days with no readout of a problem. I checked all levels and checked the odb2 with nothing. I started to Notice it does it more when my blower is blowing so I was messing with it and bam the warning came on again but this time is actually said "Lift gate Open" lol I'm not sure why it wouldn't just say that in the beginning but I shut it and it hasn't come back.
Tumbleweed1954 likes this.
STL_WJ is offline
How to stop seatbelt beeps in WK?? JHDjeep WK Grand Cherokee & XK Commander Forum 10 06-23-2011 10:04 PM
2002 WJ won't start, one ckick, three beeps, three beeps, flashing check engine lamp OverlandScott ZJ Grand Cherokee Forum 14 06-04-2009 02:30 PM
Random warning beeps? Alexia ZJ Grand Cherokee Forum 1 03-05-2009 07:21 PM
3 beeps immediately followed by the same 3 beeps MEinSoCal ZJ Grand Cherokee Forum 4 10-22-2007 01:09 AM
zj beeps w/out key in foxrox0617 ZJ Grand Cherokee Forum 3 08-30-2007 12:42 PM
