WJ Lift starting 2" BB and working up to 3" and eventually 5" - JeepForum.com
post #1 of 7 Old 03-28-2009, 08:58 AM Thread Starter
SSnipes
I am looking to buy/make parts to make a 3 to 4" lift. I could use the following.
- adjustable Track bar
- Front Quick disconnect sway bar links.
- Rear extended sway bar links
- shocks F and R
- Bump stops
- Springs longer than stock. Up country or 3" springs are Ok
- 2" budget boost ok too as I can use that with up country springs.
If you have tips or seen how to make any of these components please PM me links. thanks.
A friend of mine had spacers made from aluminum which worked very well on his XJ. he did this to offset weight from a winch. once made he put a factory spring isolator on top and bottom.
I could make it all spacer but would rather to it with some spring.
thanks all. I will post my results and cost. later.
'08 Jeep JKU Rubicon
4" TF Flex Arm, GY MTR with Kevlar 37", ASFIR bumpers, Rock sliders, aluminum skids
SuperWinch EPi9, EVO Gusset, sleeves, control arm rock sliders
Wife's - '01 Jeep Grand Cherokee 4.7L - Stock
ATS 245/70R16
SSnipes is offline
post #2 of 7 Old 03-28-2009, 09:33 AM
WJ04
- shocks F and R
- Bump stops
What ever lift hight you wan't to achieve as a finall result you have to buy componants for that hight. (I think I told you this in another thread) Dont buy componants for a 2'' or 3'' lift and try to add to that for 4'' 0r 5'' because you will have to buy all the componants again and also others that you wouldn't have needed a 3'' (with the exeption of the springs) to match the new hight.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #3 of 7 Old 03-28-2009, 10:34 AM
_Kyle_
_Kyle_'s Avatar
If you already plan on going to 5", just buy components for that now. You'll be wasting money otherwise.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #4 of 7 Old 03-28-2009, 12:13 PM
cloiselle
DO NOT WASTE YOUR TIME AND $
save up for what you really want.
cloiselle is offline
post #5 of 7 Old 03-31-2009, 10:29 PM Thread Starter
SSnipes
yeah I hear you all. unfortunately I could not shell out 2500 to $3000 grand right now for tires and lift and I needed tires. so the plan is not to waste my money. I thought I could pass on my stuff to my wifes vehicle later or
Order the IRO 4" lift, request the 6" shocks for it, and just add the budget boost spacers to it. but for the price difference I probably will just order the 6" kit. is there a big difference in the offroad flex between the 6" kits with just front long arms vs front and rear long arm kit?
My ideas change so often. man I looked at the GCOTM with 8" lift. talk about flexing... wow.
thanks all.
ATS 245/70R16
SSnipes is offline
post #6 of 7 Old 04-01-2009, 12:26 AM
TX02WJ
I second cloiselle. I am in the "build up" stage from 2" BB to 4.5". It is a royal pain. Especially if starting under 4" and going up. I'm stuck in a rut right now with crazy DW because I am having to wait for parts to come in so I can slap them on asap, so I don't pucker every day I drive to work! If could do it over I would just save a couple more bucks and wait a little bit longer and jump right into what my final goal was. However, on the plus side...I have become very familiar with a lot of the suspension components I'm working with after having to readjust everything once I install something new!
Good luck to ya brotha
02 WJ 2WD Farm-Krawler/ 4.7 liter/ 2"BB/ OME HD SS/ MX6 Pro Comp shocks/ ProComp MX6 adjustable shocks/ 31" Destination AT's/ ipod conversion/ Flowmaster 40 series
TX02WJ is offline
post #7 of 7 Old 04-01-2009, 03:02 PM Thread Starter
SSnipes
yeah that is what I was going to do. but my tires were so rotton and cracking up that they would not hold air anymore. had to do something. the tires and boost will go to my wifes GC likely so it is not a waste. Good advice! just couldnt do it due to the crappy tires. I really do want to wheel 35's. I have done 33's and loved it. with this vehicle a 6" lift and 35's is likely what will keep me happy. but 4 to 5" will be okay too. we'll see. I have seen many go with a 4" lift and put BB on top. I dont have shocks or other stuff. just the boost. were talking about $100 here. not going to break the bank with that. I can still buy the 4" or 6" for that matter. I would be wasting a $100 and my time. not a problem to me.
ATS 245/70R16
SSnipes is offline
08 Overland HEMI with intermittent "no starting" issue eric02910_HEMI WK Grand Cherokee & XK Commander Forum 18 11-27-2011 11:56 AM
"xenon" or "true white" headlight bulbs .. exist? sanboy ZJ Grand Cherokee Forum 16 10-12-2010 10:23 PM
2004 Lerado - Hood Lift Air-Loaded "things" now working lbi2000 ZJ Grand Cherokee Forum 2 12-15-2008 07:39 AM
Starting to buy parts for 3" IRO lift.. need advice! ABerry ZJ Grand Cherokee Forum 15 09-05-2008 08:21 PM
1st Azusa Trip with 4"super lift "Verdict" wccf91 WK Grand Cherokee & XK Commander Forum 4 07-16-2007 11:23 PM
