Ok, so I got my IRO front LAs on and went for an alignment. The alignment tech called me into the shop and told me the most he could do is a 0.2° caster. I explained the caster adjustment bracket to him and he rotated it a little and said it was making it negative caster. So he put it back to ~0° and said that's the best he could do.
So this is how the bracket looked when he was done.
So I just came in from rotating the axle to point the pinion down. I may be wrong but with less pinion angle you get more caster, correct? So if the pinion is pointing straight out, I'll have more caster then when it's pointing at the tcase?
So this is what its looking like now.
I may have went a little too far but I'm tempted to go back and tell them to check the caster now. Just a little confused why he told me when he rotated the axle for the pinion to point down, it gave me neg caster..
