WJ:Installing 4 in lift, only one jack? - JeepForum.com
post #1 of 17 Old 09-22-2009, 01:50 PM Thread Starter
northpaw
Hey, I am figuring how to change my suspension. I need some tips from
someone who has done this before. Is it possible to use one high lift jack and change only one spring and shock on one side at a time? Or do you really have
to get the whole front/back end up and lower the whole axle to be able to do the swap?
1999 Jeep Grand Cherokee LTD
4,7 Litre V8 Quadratrac II
4 Hella 320, 4 Boch Big Knick, JULA Roof rack, 245/75/16 General Grabber AT2, IRO 4 inch Lift kit
northpaw is offline
post #2 of 17 Old 09-22-2009, 02:00 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
If you have some jackstands, sure it will work.
~James
ezflip is online now
post #3 of 17 Old 09-22-2009, 02:00 PM
KDog223
I would not trust a highlift for doing work like that. Make an investment into a decent floor jack and a couple of jack stands. FWIW I had to really put some weight on my axles (espc. the front) to get the old springs and BB out and to get the new 4" springs in. I might change a tire with a high lift but that's about it.
KDog223 is offline
post #4 of 17 Old 09-22-2009, 02:03 PM Thread Starter
northpaw
Well, maybe my definition of a high lift jack was not clear, what i meant was of course a floor jack that lifts high.
So, conclusion: I need to lift the whole front/back end? And how high? would the height of 50 cm (1,5ft) jack stands suffice? or do i need even more?
northpaw is offline
post #5 of 17 Old 09-22-2009, 02:10 PM
UrbanOffRoad124
I guess it could be done but for safety reasons you should really support the vehicle on jack stands, then use a floor jack to support the axle / drop it left and right to do each side. Using a floor jack to lift the right side of the axle makes the right side drop more and visa versa. It makes it alot easier to lift the vehicle as high as needed to get the maximum droop out of your axle. Disconnecting your track bar, sway bars, and shocks lets the axle droop as much as your control arms will allow for the most part. A coil spring compressor will probably be needed for 4" lift springs. Do it right and safe man! Get some jack stands and a floor jack, they're never a bad investment!
Edit: By the time I replied, others beat me. Didn't mean to sound repetitive.
'02 WJ | 4.7HO | Limited | QDII | 3.5" Lift (BB+OME Springs) | JKS TB | JKS Quick Disco's | JKS BPE's | RC Nitro 9000's | Rusty's SS | K&N FIPK | 40 Series Delta | Cat-Delete |
Coming soon: 31" KM2's | 15x8 Cragar V-5's
#236 |
#232
"those who do, can't explain; those who don't, can't understand"
UrbanOffRoad124 is offline
post #6 of 17 Old 09-22-2009, 02:14 PM Thread Starter
northpaw
well ok, i got a couple of spring compressors but I cannot find any heavy duty that can compress them more than 2-3 inch, wich is practically nothing in this case
northpaw is offline
post #7 of 17 Old 09-22-2009, 02:22 PM
UrbanOffRoad124
I would imagine that would be high enough. You'll have your wheels off so you can let the axle droop down until your brakes get close to the ground. I don't have any special jack stands. I have a nice Craftsman floor jack, and some 3 ton jack stands but I'm not sure how high they go. They go high enough for everything I've installed so far.
#236 |
#232
post #8 of 17 Old 09-22-2009, 02:24 PM Thread Starter
northpaw
Thanks, that info actually helps a lot
northpaw is offline
post #9 of 17 Old 09-22-2009, 02:30 PM
UrbanOffRoad124
You can usually rent strut or coil spring compressors from most parts stores. Always use the saftey clamps. Once you get those springs compressed, they're a grenade ready to go off.
#236 |
#232
post #10 of 17 Old 09-22-2009, 02:33 PM Thread Starter
northpaw
Maybe in USa you could do that, not in sweden, here you need to buy, and I havent found any better things than these:
northpaw is offline
post #11 of 17 Old 09-22-2009, 02:42 PM
KDog223
Nope, I didn't need one. Just loosen everything and push down as hard as you can on the axle and it'll go in.
Edit: I said push but actually I sat on the caliper to get all my weight on it Another pair of hands would have helped too.
KDog223 is offline
post #12 of 17 Old 09-22-2009, 02:43 PM Thread Starter
northpaw
Thanks, and then use the jack to push the axle back?
northpaw is offline
post #13 of 17 Old 09-22-2009, 03:31 PM
KDog223
Not really, once the new spring is in place the axle is pretty much where it's going to be (minus the weight of the vehicle on it). I think on the second side I actually used ratchet straps as a mock-spring compressor just to get that extra ~1/2" of clearance but I think having someone else there to push down on the axle while I fit the spring would have worked too.
KDog223 is offline
post #14 of 17 Old 09-22-2009, 04:37 PM
BlackShuck
I used a spring compressor when I put mine in. I was doing the whole job alone so maybe that played a factor. I used two jack stands, a bottle jack, and the jack that comes with the Jeep. (did my install 3-4 months ago)
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline
post #15 of 17 Old 09-22-2009, 06:36 PM
FirefightinWJ
I used spring compressor, 2 jack stands, and a floor jack. You can get by without spring compressors, but you may have to disconnect the LCA's. Taking the sway bar links off will also help getting the axle to droop and/or lift enough to pop the springs out.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
Where do I put my jack to lift? kmk108 ZJ Grand Cherokee Forum 6 03-10-2009 03:00 PM
Hi-Lift Jack Mounting micallef WK Grand Cherokee & XK Commander Forum 4 10-26-2008 08:10 PM
Where to jack from with Hi-Lift? mopar3389 ZJ Grand Cherokee Forum 9 05-10-2008 08:03 PM
Installing BB, will this jack be ok? tyler711 ZJ Grand Cherokee Forum 23 04-30-2008 02:01 PM
HI lift jack?? xjmark85 ZJ Grand Cherokee Forum 15 04-01-2008 01:40 PM
