WJ HVAC Removal - JeepForum.com
post #1 of 5 Old 01-03-2010, 02:14 PM Thread Starter
markywmson
Junior Member
WJ HVAC Removal
Hi all
I got the instrument panel off, and down to the firewall and the HVAC box. It's miserably cold in Connecticut right now, so the rest is going to have to wait until tomorrow.
I wanted to see if there was an easy or good way to reach those connectors at the engine side of the firewall to disconnect the HVAC box and get it out.
Seems like a very long reach and not much room to maneuver. Is there anything that I should be taking off to make my life easier in there? I need to take both heater hoses off and the AC lines. I've already evacuated the AC system.
It looks like the heater lines are just held on with 2 constant tension clamps. I would assume the AC lines are a quick disconnect type fitting like was on my old ZJ?
Thanks for any and all help. Much appreciated. Hopefully can get it taken care of tomorrow morning and get the blend doors and recirc replaced quickly.
-mark
markywmson is offline
post #2 of 5 Old 01-03-2010, 02:40 PM
WJChris
WJChris's Avatar
WJChris is offline
post #3 of 5 Old 01-03-2010, 03:18 PM
crashcraddock
Also www.jeepsunlimited.com/forums/ has a good write-up with extra notes like bolt sizes and helpful tips. It's an addendum to the WJJEEPS write-up. I took out the bat., the coolant res., and moved the ECU over WITHOUT disconnectiong it.
crashcraddock is offline
post #4 of 5 Old 01-03-2010, 03:25 PM
crashcraddock
post #5 of 5 Old 01-03-2010, 10:37 PM Thread Starter
markywmson
Junior Member
Originally Posted by crashcraddock View Post
thank you very much. that's exactly what i was looking for. i got the wjjeep writeup in hand, just needed some help on the little things that go with it.
much appreciated!!
-mark
HVAC Assembly removal for recirc door replacement Puppetmaster_sr ZJ Grand Cherokee Forum 6 11-05-2008 09:30 AM
HVAC Nightmare sixpackFL ZJ Grand Cherokee Forum 2 08-14-2007 02:34 PM
Hvac Removal Helppp!! 99 Wj GRDCHRKE555 WJ Grand Cherokee Forum 21 08-02-2007 12:28 PM
HVAC hot only Izzy ZJ Grand Cherokee Forum 0 04-23-2007 03:26 PM
HVAC Removal HELP 99wjman ZJ Grand Cherokee Forum 2 01-13-2006 05:39 PM
