WJ High Idle Switch - JeepForum.com
post #1 of 11 Old 01-19-2009, 06:13 PM Thread Starter
comptiger5000
WJ High Idle Switch
I may be getting a 99 WJ Laredo (4.0 I6) at some point over the next year. Out of curiosity (and because I can't find any answer to this), is it possible to add a high idle (or "extended idle") switch to one of these, like on the 4.0 XJs? If so, how complicated would it be? If there is no simple way of doing it, is there a way to trick the TPS to raise the idle to about 1200rpm on command?
comptiger5000 is offline
post #2 of 11 Old 01-19-2009, 07:23 PM
theksmith
2003 WJ
interested in this as well, i did it on my old cherokee and it was as easy as grounding a single wire with the switch. to my knowledge though, the WJ wasn't a popular government/police vehicle, so i don't know if it ever had that option.
i know there was a writeup somewhere about making the cruise-control switches work even in PARK to raise the idle as much as desired... not sure where that was though
theksmith is offline
post #3 of 11 Old 01-19-2009, 08:32 PM
madrabbitt
madrabbitt's Avatar
on the 92+ cherokees its in the computer.
On the WJ's it may be as easy as a programmer that plugs into the obd port, but i havent heard of anything.
It would a nice option though
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #4 of 11 Old 01-19-2009, 08:57 PM
windsors03cobra
windsors03cobra is offline
post #5 of 11 Old 01-19-2009, 09:00 PM Thread Starter
comptiger5000
I see one problem with a hand throttle... Aren't those meant for carb-ed engines? Unless I'm missing something, I don't see a way to mate one of those to an EFI engine with a TPS.
post #6 of 11 Old 01-19-2009, 09:14 PM
windsors03cobra
The first link has pictures of the whole install the guy did on a EFI 4.0.
A EFI throttle body is similar to a carb but without the gasoline mixing aspect, linkage-venturi(s) and throttle plate(s) are still right on the "carb like" throttle body.
post #7 of 11 Old 01-19-2009, 09:19 PM
theksmith
2003 WJ
yeah, you're missing something
post #8 of 11 Old 01-20-2009, 05:23 AM Thread Starter
comptiger5000
Ok. That sounds like the easiest way to do it then.
post #9 of 11 Old 01-20-2009, 09:36 AM
alexsious
forgive me for asking, but what does High Idle do?
alexsious is offline
post #10 of 11 Old 01-20-2009, 11:00 AM Thread Starter
comptiger5000
High idle raises the engine RPM at idle (in Park or Neutral) to 1200-1400 rpm (sometimes 1000). This improves alternator output when you are going to be idling for a few minutes, as well as allowing faster warm up on cold winter mornings. Also, it is bad for an engine (less oil to top end, fuel dilution of oil, etc) to run at a normal idle for more than a few minutes. At high idle, these problems are reduced or eliminated.
post #11 of 11 Old 01-20-2009, 01:02 PM
madrabbitt
madrabbitt's Avatar
on the topic of improving alternator output, most alternators put out their peak amperage at typical driving RPMs, not idle. So, running high draw electronic accessories at idle can actually drain the battery.
This is why police and service vehicles typically have an extended idle option.
WK CRD 07 - high idle, how to? basthen WK Grand Cherokee & XK Commander Forum 33 10-19-2012 12:46 AM
High idle trowley ZJ Grand Cherokee Forum 7 05-10-2008 11:23 PM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 08:43 AM
Idle Jumps High After Sitting at Idle gunthagunth ZJ Grand Cherokee Forum 0 09-21-2006 09:58 PM
High Idle, No Over-D... Brian's 97 ZJ ZJ Grand Cherokee Forum 1 11-11-2001 02:35 AM
