WJ: Gas Tank Raise...Couple Q's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > WJ: Gas Tank Raise...Couple Q's
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 07-27-2009, 09:56 AM   #1
StrokedWJ
StrokedWJ's Avatar
I'm in the middle of this project and have a couple of questions that I couldn't find answered in some previous writeups.
1) Is body panel adhesive strong enough to use for the piece that covers the old spare tire well? I'm running flux-core wire in my welder (Lincoln-180T) and am not very optimistic about trying to stitch weld the 1/8" plate to the thin sheetmetal in the back of the WJ.
2) How much clearance should there be between the tail pipe and the gas tank? I had to cut out the heat shield that was in place to get the gas tank up high enough. Now I'm worried that it might be too close to the plastic. I sure as hell don't want it to end up melting!
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline   Reply With Quote Quick reply to this message
Unread 07-27-2009, 12:16 PM   #2
StrokedWJ
StrokedWJ's Avatar
Just got back from talking with a guy at the body shop. He recommended a product called Fusor. Its a body panel adhesive and he said it'd be just as strong as welding. I'm gonna give it a try and see how it works. The good part about it is it bonds and seals, so that eliminates the need to run a bead of RTV or something around the panel.
http://www.lord.com/Home/ProductsSer...0/Default.aspx
Unread 07-27-2009, 02:29 PM   #3
dmolaver15
i used flux core when i welded mine all back up, and it's held up fine since then
not sure about the clearance on the gas tank and tail pipe though, mine dumps before the rear tire
i'd say maybe 4 or 5 inches to be safe, but you could just use the old heat shield and bend it around to make another shield
04 WJ 4.0
6.5" IRO Front and Rear Longarms
Soft 8's, 285/75/16 BFG Mall Terrains
Super 44 with 3" Side Dump
Dana 44a, 4.56's
My Build Thread: http://www.jeepforum.com/forum/f197/evolution-my-wj-623825/
dmolaver15 is offline   Reply With Quote Quick reply to this message
Unread 07-27-2009, 02:32 PM   #4
QuadraTokn
1930 WJ
uuum flux core can do anything if you weld it well enough.
LIKE US ON FACEBOOK: Valhalla Fabrication
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline   Reply With Quote Quick reply to this message
Unread 07-27-2009, 03:28 PM   #5
StrokedWJ
StrokedWJ's Avatar
Were you using a 110v or 220v welder? Right now current clearance is less than 1" between the tail pipe and skid. I guess I'll have to cut a section of the pipe out and reweld it to move it over as far as possible.
Quadra, flux core burns hotter than gas shielded solid core. It would be fairly easy to weld it in using .025 solid core wire and gas, but I don't have a regulator yet (been waiting on if for over 4 weeks). My concern was with the FC I'd blow through the sheetmetal and make more holes.
Unread 07-27-2009, 04:22 PM   #6
QuadraTokn
1930 WJ
Just move faster with a tighter arc. But if you will have a working solid core welder soon then I would use that.
Unread 07-27-2009, 04:31 PM   #7
dmolaver15
i only used a 110v, 220 would probably burn right through
04 WJ 4.0
Dana 44a, 4.56's
My Build Thread: http://www.jeepforum.com/forum/showthread.php?t=623825
Unread 07-27-2009, 04:38 PM   #8
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
My 220, on the lowest setting, acts similar to a plasma cutter when it comes to sheet metal. It kinda-sorta works but a 110 would be much preferred.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 07-29-2009, 12:11 PM   #9
StrokedWJ
StrokedWJ's Avatar
I got it finished up yesterday. Ended up using the Fusor body panel glue on the new floor panel. Man that stuff stinks! I followed along the lines of AgitatedPancake and his writeup & pictures were very helpful. I picked up a piece of 3/16" sheet and will make a skid next.
Arlo, I tried practicing on a small piece of the sheetmetal that I'd cut out and I don't think you could have described it any better.
Unread 07-29-2009, 12:47 PM   #10
StrokedWJ
StrokedWJ's Avatar
Pics:
Unread 07-29-2009, 01:34 PM   #11
Bama_WJ
Looks great. You can't even tell its there anymore from the rear. Time to swap that D35 out of there. lol
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 07-29-2009, 01:37 PM   #12
AgitatedPancake
Beautiful man, yours came out exactly like mine did! Glad I could help ya out!
*EDIT* The only bummer about yours is the no fuel pump opening, I would hate to not have it =P
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
