WJ front lower control arms mounted in the rear of a ZJ? - JeepForum.com
post #1 of 5 Old 05-17-2013, 05:58 PM Thread Starter
C_ee_X
1989 XJ Cherokee
We all know we can swap in front control arms in our ZJs but how about using front lower control arms from a WJ and installing them in the rear (replacing the ZJ's stock rear lower control arms)
Is it possible? Is it safe? Would it be beneficial?
Logically, I think it's possible since they are the same length but I don't know if CAs can be installed in reverse.
C_ee_X is offline
post #2 of 5 Old 05-17-2013, 06:15 PM
dusterdude
Interesting thought
dusterdude is offline
post #3 of 5 Old 05-17-2013, 06:43 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
we tend to use them on the front because of the bow to them for tire clearance. no benefit like that for the rear. they'll fit, they'll be nominally safe, no major upgrade though other than the slight increase in rigidity.
ratmonkey is offline
post #4 of 5 Old 05-17-2013, 07:02 PM
dnuccio
they clear tires better on the front? that might be just what i need, mine rub the control arms at full lock.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 5 Old 05-18-2013, 03:26 AM Thread Starter
C_ee_X
1989 XJ Cherokee
Thought so! I already have WJ CAs for the front.
I need to replace the bushings in my rear CAs and being in France parts are overly expensive: +/-400 USD for 4 new CAs or just about half of that if I only want the bushings.
So because I'm rather cheap, I'd rather find second hand parts that will fit and also improve the ride (those WJ bushings seem incredible!) and I found one or 2 ads for WJ CAs that I'll check out today!
Thanks for the input!! :-)
C_ee_X is offline
control arms , front , lower , rear , swap
