WJ Front End Noise - JeepForum.com
post #1 of 9 Old 07-29-2009, 05:53 PM Thread Starter
fast_man58
WJ Front End Noise
Alright, first some background info. 400 miles ago i replaced the front axle seals. This inolved pulling the differential and axle shafts, as you probably know. Every thing went well. The shims and caps were put back exactly as they came out, and the leak was fixed. All was good for a week and a half now untill i heard some moaning coming from the front end this morning on my way to work. The noise sounds almost like a wheel bearing/hub, but they have no play on both sides. The CV axle shafts also have no play in them, so i'd like to rule them out as well. I've spent a few hours trying to diagnose the problem tonight, with no avail. About 4 months ago, i reaplaced the CV joint on my front driveshaft, as it was on its way out. When i removed the driveshaft today, the moaning went completly away. I'd also like to mention that the moaning only occurs under accelearation, and starts to make noise at 25 MPH. Above 30-35, the noise subsides some, but its still there. When coasting, or braking, there is no moan. The backlash between the ring and pinion is about 5-7 degrees i'd guess.
I've searched several pages about this, and have come up with alot of different things it could be, but no real answer.
Any help would be greatly appreciated, as im planning on taking it to CO at the end of next month.
Thanks
All of us could take a lesson from the weather. It pays no attention to criticism
night crew #078
fast_man58 is offline
post #2 of 9 Old 07-29-2009, 08:13 PM Thread Starter
fast_man58
anybody have any advice? i put it in 4 low and ran it up to 25 MPH with the same results.
night crew #078
post #3 of 9 Old 07-29-2009, 08:16 PM
gatorayde
So you took out the DS and it went away, you found the problem. It's probably a bad driveshaft CV joint.
gatorayde is offline
post #4 of 9 Old 07-29-2009, 08:46 PM
table
table's Avatar
2015 JK Wrangler
Possibly this?
http://www.wjjeeps.com/tsb/tsb_wj_030500.pdf
2015 Anvil JKU | Sahara | Manual | 3.73
RIP: 2000 WJ | Initiated Destruct Sequence One | Code: 11A
table is offline
post #5 of 9 Old 07-29-2009, 09:02 PM Thread Starter
fast_man58
im hoping that its the DS. i was planning on getting a new shaft from Woods or Carolina anyways soon. it just seems like a strange coincidence that a week after i tear my front end totally out, the driveshaft starts making noise.
night crew #078
post #6 of 9 Old 08-17-2009, 04:46 PM Thread Starter
fast_man58
A bit of an update. I just installed the new Carolina shaft and the noise is still present. The fluid in the front axle is spotless with no shavings of any sort on the magnetic plug. It had zero noise in the 3-400 miles i ran with no front shaft. At this point in starting to wonder if my T-case is the problem. There is no power sent to the front end unless slip is detected, so im thinking that the drag of the front end is sent through the front driveshaft and is upseting somthing internally. The T-case oil is fairly clean with about 15K miles on it. Im going to change it as we speak an see if it helps any.
I need to take the jeep to Colorado and back this next week. Any input would be greatly appreciated.
Thanks
night crew #078
post #7 of 9 Old 08-17-2009, 05:32 PM
gatorayde
Hmm, if you have access to a 2 post lift, have someone lift it up and rev it to 20-30mph and see where it's coming from underneath. It's either the diff or T case at this point (hopefully T case as it's an easier/cheaper fix, and you can do a 242 swap while you're at it)
post #8 of 9 Old 08-17-2009, 06:52 PM Thread Starter
fast_man58
well i think i narrowed it down...a bunch. while draining the T case, i noticed 2 little silicone rings about 3/16" diameter came out. on the drain port, there is somthing black plastic. it almost appears to be a chain guide, or perhaps an oil pick up for the pump? well its somewhat loose, but not maneuverable enough so i can get a magnet stick in there.
im going to do some searching for 247 pictures.
worst case scenario, i would just drive to CO with 2wd.
night crew #078
post #9 of 9 Old 08-17-2009, 07:27 PM Thread Starter
fast_man58
nvm. its coming from the front
night crew #078
howling noise front front of 01 WJ aquafresshness ZJ Grand Cherokee Forum 7 05-25-2009 10:50 AM
front noise after removing front skid plate davets ZJ Grand Cherokee Forum 2 12-08-2008 05:54 AM
help with front end noise nisilvia ZJ Grand Cherokee Forum 2 12-06-2008 02:07 AM
Help! Front Diff Noise Or T-Case Noise ntaousakis ZJ Grand Cherokee Forum 6 04-21-2008 11:39 PM
front end noise K-Pax ZJ Grand Cherokee Forum 2 01-29-2005 09:51 PM
