WJ front brakes need replacing, what should I use? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > WJ front brakes need replacing, what should I use?
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 05-17-2009, 11:19 AM   #1
TheSandman
So I replaced my brakes on my WJ probably about this time last year, new pads and rotors. My rotors are beginning to warp so I'm in need of some new ones. The last ones I bought were from advance auto, which aren't the best quality IMO. I'm looking for a decent brake upgrade that won't burn my wallet up. I was looking into EBC setup, but their website sucks and I can't find prices anywhere for them.
I also looked on tire rack and might go with the Brembo blanks for about $50 a peice and maybe hawk pads?
Any other advice?
04 WJ 4.0 - Stock
96 XJ 4.0 - RE 7.5" LA, Locked HP44/9", 36 TSL's soon
TheSandman is offline   Reply With Quote
Unread 05-17-2009, 04:03 PM   #2
ZJPunk98
Addicted to my Jeep
ZJPunk98's Avatar
www.perfectbrakes.com ebc stuff... good site with prices. Read this: http://www.jeepforum.com/forum/f13/performance-brakes-761549/
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote
Unread 05-17-2009, 06:45 PM   #3
TheSandman
Originally Posted by ZJPunk98 View Post
good deal man, did you order your EBC stuff through them?
One more question, it's asking me if I have ATE or AKEBONO, what do I have? I'm assuming it's talking about the rotors I have, I know that some came with composite rotors and other had steel?
04 WJ 4.0 - Stock
Unread 05-17-2009, 06:57 PM   #4
keith20mm
I replaced rotors with drilled rotors, and 15k later, almost all in steep grades and towing, no warpage yet, unlike the last plain rotors. I use AZ gold pads, and they seem to be just fine.. non-ceramic...
keith20mm is offline   Reply With Quote
Unread 05-17-2009, 07:56 PM   #5
indept
They're asking about the calipers. You SHOULD have akebono's on an '04. The other stock calipers on earlier models were Teve's which had a big spring clip on the outside of the caliper which is visible when you looked through the wheel at the caliper, this spring is about 10" long so if you have it you can't miss it.
2000 WJ 4.0L 42RE 242 TC
172,271 miles & counting
indept is offline   Reply With Quote
Unread 05-17-2009, 08:03 PM   #6
TheSandman
sweet, I'll check it out tomorrow.
Looks like I'll go with a EBC setup with solid rotors and green pads.
Thanks
04 WJ 4.0 - Stock
Unread 05-17-2009, 11:20 PM   #7
tennesseewj
You should definitely have the Akebonos.
I used the Brembo rotors from TireRack on mine and have no complaints. Been over a year now.
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline   Reply With Quote
Unread 05-18-2009, 12:24 AM   #8
steve0410
ive been having the same problem with my grand cherokee i put new rotors and pads on almost every year ..still havnt found a fix....
steve0410 is offline   Reply With Quote
Unread 05-18-2009, 04:54 AM   #9
TheSandman
what about hawk pads? anyone use those?
04 WJ 4.0 - Stock
Unread 05-18-2009, 05:40 AM   #10
cherojeep
i used Brembo blanks and Hawk LTS pads on my f150 and never had a problem. i have brembo and hawk pads on my TSX and love them on there
I will use them again when brakes are needed.
2004 Jeep Grand Cherokee
2009 Honda Civic Si
cherojeep is offline   Reply With Quote
Unread 05-18-2009, 07:27 AM   #11
JerseyWJ
2012 WK
I use Hawk high performance street pads, which ever they, are on power slot rotors...
DO NOT get power slot rotors, expensive and warp just as easily and their limited lifetime warranty does not cover warpage at any time. Their customer service is awful too.
The Hawk pads are good though, no dust. As far as stopping power, I think they are the same as any other decent pad. I'm changing mine out too, EBC green pads.
Traded my Columbia WJ for a WK2
JerseyWJ is offline   Reply With Quote
Unread 05-18-2009, 07:30 AM   #12
xJoshxx
2011 WK
Stillen Pads and Rotors From Kolak.
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 Laredo with ORA1
xJoshxx is offline   Reply With Quote
Unread 05-18-2009, 12:55 PM   #13
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
brembo
WALTER
walter_da_jpr is offline   Reply With Quote
Unread 05-18-2009, 03:08 PM   #14
Steve01WJ
Steve01WJ's Avatar
2005 WK
I have hawk pads all around on standard rotors with oem size tires. They work verry well. They tend to squeal slightly when cold though. If i didnt have abs they could lock up easy if you wanted
12 JKU, 2.5TF BB, MTR 35s on 15"procomps
05 WK 5.7 Limited QD2
Steve01WJ is offline   Reply With Quote
Unread 05-18-2009, 03:29 PM   #15
TheSandman
I may go either the brembo route or the EBC route, not sure if I will run the green EBC pads though, I'll probably run their OEM equal pad.
I like the stillen's too, but they are too expensive for me, not worth it IMO.
Thanks
04 WJ 4.0 - Stock
