WJ factory spring isolators - JeepForum.com
post #1 of 1 Old 09-29-2008, 09:45 AM Thread Starter
davets
1956 CJ5
Can I add a 2nd factory spring isolator on the front of my 02 WJ? It will lift it 1" if I can. I've done it on an XJ before but that isolator is just a flat spacer and the bumpstop is very long which keeps it in place. On the WJ the spacer has a tapered inside hole which is mostly much larger that than the bumpstop it slides over. Also, only about 1/2" of bumpstop extends beyond the factory spacer so a second spacer would barely grab that bumpstop which could cause it slide out. Anyone ever do it? I know 3/4" spacers are available but I was looking for 1" in front and the rear will take a 2nd stock spacer which will add 5/8". They were free from the junkyard. Thanks.
*** 1956 CJ-5, milled head,elec fan,power steering,4-whl discs,rubber mounted cage,all drivetrain and engine incl distributor vented into firewall,Saturn overdrive,Lockrites,Rezeppa joints,2 1/2" springs arched add'l 1 1/2", homemade expanding shackles,reinforced frame,glass tub, stainless tank, 31X15.5 Terras on 15x10 and 15X12 rims-trail, 31X10.5 A/T's on 15X10 alum rims-street,Amsoil.
davets is offline
IRO 3.5 Lift With .75 Spring Isolators jnjtrevino ZJ Grand Cherokee Forum 5 05-28-2009 08:58 PM
Spring isolators runnerboy2010 ZJ Grand Cherokee Forum 3 04-25-2009 07:52 PM
1 spacer or 2 isolators? rustynail ZJ Grand Cherokee Forum 7 04-22-2009 05:45 PM
Rubi 2'' BB isolators?? TheCompound ZJ Grand Cherokee Forum 13 11-21-2006 10:45 AM
Coil/Spring isolators -Joe- ZJ Grand Cherokee Forum 5 02-20-2006 11:16 AM
