Wj experts advice What repairs need attention and which dont? - JeepForum.com
post #1 of 6 Old 04-08-2009, 09:26 AM Thread Starter
chonger
I was at my jeep dealer getting a front end alignment and they noted some items that need to be addressed. Are some of these common to a Wj with 100,000 and arent too big an issue? Which need to be addressed if any....
1)Power steering return line has a leak
2)Right front CV boot is leaking
3)Trans output shaft seal is leaking
4)Transfer case input seal is leaking
My 99 wj has 100,000 on it for reference....
Thanks,
CHris
chonger is offline
post #2 of 6 Old 04-08-2009, 09:29 AM
99avant
None of those NEED to be addressed immediately. I would take care of them as soon as the budget allows.
The first one to take care of is the CV boot, replace the whole shaft.
And keep an eye on the fluid levels.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #3 of 6 Old 04-08-2009, 09:31 AM Thread Starter
chonger
Forgot these items too
Rear brakeline rusted
Upper control arms are rusted severely
chonger is offline
post #4 of 6 Old 04-08-2009, 09:34 AM
GraKee99
Rapist Wit
GraKee99's Avatar
If the upper arms are starting to rust through, I would replace those soon as snapping one those while driving would not seem that fun to me.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #5 of 6 Old 04-08-2009, 12:41 PM
JTM1
1988 XJ Cherokee
Upper Control arms then the power steering return line.
Justin
88 XJ-Lifted, Locked, and on Jackstands
69 CJ5-In peices
JTM1 is offline
post #6 of 6 Old 04-08-2009, 01:39 PM
CrazyWalnut13
The power steering return line is something that you can easily do yourself. And it shouldn't cost much because it's just a short rubber hose.
1. Take out airbox
2. Remove the three bolts holding the PS pump to the engine block (be patient, these are loooooong bolts and they're in a tight space)
3. See if you can twist the PS pump around to get to the return line on the bottom. If you can, skip to step 5; if you can't, then go to step 4.
4.Take off the pressure out line (you'll NEED an 18mm flare nut wrench, don't even try any other tools or you may round the bolt). Now twist the pump around to get to the bottom.
5. Remove hose clamp from the nipple, and slide the rubber hose off.
6. Remove the other end of the hose from the PS gear
7. Put everything back together in reverse order.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
WJ repairs...need input cherojeep ZJ Grand Cherokee Forum 2 08-29-2009 04:22 AM
Attention all ovaled track bar mount experts. BlackShuck ZJ Grand Cherokee Forum 8 08-06-2009 12:17 AM
More repairs for 02 Overland...Need help! greggblue ZJ Grand Cherokee Forum 7 07-28-2009 08:08 PM
Advice from some experts... ThePope ZJ Grand Cherokee Forum 8 07-04-2007 04:30 PM
Anyone good with A/C repairs? dday930 ZJ Grand Cherokee Forum 4 06-29-2005 11:24 AM
