WJ engine code 0735? - JeepForum.com
post #1 of 4 Old 09-24-2009, 03:55 PM Thread Starter
kennadm
Hi all,
The past couple of days, I had noticed by transmission shifting a little rougher than normal ('02 GC Limited 4.7, 80K miles). Yesterday the check engine light came on and I pulled these codes: P0138 and P0141, which are related to the O2 sensor, which I understand. However, I also got a P0735 - Gear 5 Incorrect Ratio 17119. The transmission is barely shifting rougher than normal; someone who hasn't driven it before probably woudn't even notice it. But as far as I can tell, fifth gear is fine. Where should I begin to diagnose this problem? (I hope I don't have to start worrying about rebuilding it! )
Thanks for any advice!
kennadm is offline
post #2 of 4 Old 09-25-2009, 11:23 PM Thread Starter
kennadm
....nothing?
kennadm is offline
post #3 of 4 Old 09-26-2009, 05:59 AM
QBCoach
First things first...Low fluid can be the cause of many transmission problems...so I would check that first...if its low add or better yet do a complete tranny fluid flush and refill. See if that helps. But from reading the manual if you are onlt getting P0735 then it looks like it maybe internal in the tranny. The two usual problems are the Transmission Oil pump and the pressure control solenoid.
Hope this helps! I hate seeing lonely post
02 WJ Overland- Daily Driver...keeping it stock for now
94 YJ- work in progress
"If it ain't broke...just give it time!"
QBCoach is offline
post #4 of 4 Old 09-26-2009, 08:57 AM Thread Starter
kennadm
Thanks for the reply! The level is fine... Guess I've got some work to do...
kennadm is offline
Engine code Uncle_Fester ZJ Grand Cherokee Forum 1 10-11-2009 07:19 PM
Engine Code help- Code 11 athomas08 ZJ Grand Cherokee Forum 3 05-07-2009 12:56 AM
Engine Code 31 Jagillac ZJ Grand Cherokee Forum 1 12-29-2008 02:35 PM
Engine code 32 lma1973 ZJ Grand Cherokee Forum 9 02-05-2008 01:49 PM
Engine Code 135 and 155 BradTE20 ZJ Grand Cherokee Forum 22 12-12-2005 07:47 AM
