WJ double cardan rear driveshaft? - JeepForum.com
post #1 of 8 Old 10-02-2008, 08:05 AM Thread Starter
67jeepstang
Is it true that the 2004 model year laredo was the only wj year that they used a double cardan rear driveshaft, or is this false cuz that would really help when considering a 4-6" teraflex lift since its such an extreame driveline angle.
67jeepstang is offline
post #2 of 8 Old 10-02-2008, 08:31 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
No, the 2004 WJ didn't have a rear DC DS...
And I would suggest looking elsewhere besides teraflex for a 4-6" lift (I assume you are looking at their old long arm lift).
Check out
-Clayton Offroad Manufacturing or...
-Iron Rock Offroad
Both make a better long arm kit.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 8 Old 10-02-2008, 09:33 AM Thread Starter
67jeepstang
yeah i was. but i didnt know it was old. im currently installing a 2"BB from skyjacker but in the future i wanted to put on the long arm. i just see teraflex splattered all over the internet thats why i thought them. why do you have a better manufacturer? and then i guess my question is...what is the rubber boot on the driveshaft right out of the transfere case? any help with lift kits would be greatly helpfull.
post #4 of 8 Old 10-02-2008, 09:42 AM Thread Starter
67jeepstang
I looked into that Iron Rock Offroad site and that was very helpful i was looking at the 3" but it didnt come with a transfere case drop kit. is that something not needed till 4"? otherwise i might wait and save some money and get the 3" instead of the skyjacker 2" BB. what do you think
post #5 of 8 Old 10-02-2008, 11:08 AM
gearhead998
I would definatly save your pennies for the 3". I like springs instead of blocks. I am planning on a 4" IRO on my wife's WJ in the spring.
gearhead998 is offline
post #6 of 8 Old 10-02-2008, 11:13 AM
ArloGuthroJeep
Mr. Hyde!
Without getting into too much on the details on Teraflex, their main fault is that they keep the stock upper CA's which causes bad geometry with the pinion angle.
The rubber boot on the driveshaft coming out of the TC is actually on the transfer case, not the drive shaft. It just protects the splines of the transfercase output shaft and has grease under it. You can pull it back and look at it.
A TC drop isn't really necessary even at 6" if you get your pinion angles set up properly. I am at 6" and have on super minor vibration that I just havent' bothered to eliminate...
FWIW (For What Its Worth) Claytons is the bomb! It is more expensive, and requires more modifications, but it can't be beat offroad IMHO.
post #7 of 8 Old 10-02-2008, 11:17 AM
WJChris
WJChris's Avatar
WJChris is offline
post #8 of 8 Old 10-02-2008, 11:46 AM Thread Starter
67jeepstang
well i think i made up my mind. im going with the 3" IRO whenever i get the money and at least i no longer have to worry about the TC drop kit.
multiple double cardan driveshaft - revisited skain8 ZJ Grand Cherokee Forum 11 12-09-2013 01:00 PM
WJ: 4.0 Double cardan u-joint driveshaft for under $50 iluvtruenos ZJ Grand Cherokee Forum 1 02-20-2011 03:43 PM
Stock Double/Single Cardan Front Driveshaft FirefightinWJ ZJ Grand Cherokee Forum 6 12-08-2009 01:49 PM
WJ caster with front double double cardan DS doublejz ZJ Grand Cherokee Forum 3 07-30-2009 10:48 AM
front driveshaft double cardan? arsonist_bob ZJ Grand Cherokee Forum 12 03-21-2009 05:33 PM
