WJ door latch fix - JeepForum.com
post #1 of 10 Old 04-06-2007, 05:39 PM Thread Starter
gpJeep
WJ door latch fix
I just replaced the door latch in my wj
but I was wondering what makes trhem go bad and start buzzing?
Can the old latches be taken apart and repaired >?
has anyone done that ?
maybe a small winter project ...
thoughts ?
POLISH - CANADIAN ........... JEEP Lovers CLUB
gpJeep is offline
post #2 of 10 Old 04-06-2007, 11:20 PM
Bob D.
I assume you're talking about the lock actuator/motor.
I've never taken one apart, but I think it's the gears that strip.
Got a source for new gears? That's probably why no one attempts to repair them.
Bob D. is offline
post #3 of 10 Old 04-08-2007, 01:42 PM
Double E
Double E's Avatar
I'm an idiot let me just get that out of the way.
I had a rear passenger door start buzzing when the automatic door lock engages. I took out my trusty service manual and decided that I would just find the wire to the door lock, cut it and do the repair later.
First I cut the wrong wire and did not re-connect it, then I cut the right wire and I thought I was all set, so I just closed the door and was all done...right?
nope. Now the door is permanently locked and the manual door lock does not slide to the unlock position. Something is blocking it from unlocking and...as you can imagine, the door is not opening. I figure there's a common, well known reason for the buzzing & it's probably the same thing yall had.
First, does anyone know if it's also possible to take apart enough of the door while closed to get it open, then...what part am I going to neeed to fix the original problem? Next, am I going to have the same issue with the other 3 doors?
I looked at wjjeeps for info on this but did not see anything. Did I miss it?
Thanks in advance. If there's no info on it here I guess I'm gonna neeed to study the manual for this one...
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 10 Old 04-08-2007, 07:59 PM
Bob D.
Disconnecting the actuator should not have any effect on the manual lock switch.
I can't imagine how they would be related, but did you try to reconnect the wrong wire that was cut?
How about just trying to unlock it with the key in the door lock?
Not sure how far you would get trying to pull the door panel with the door closed - you need somewhere to pry the trim from the door, and the front of it is flush with the dash.
Bob D. is offline
post #5 of 10 Old 04-09-2007, 06:48 AM
Double E
Double E's Avatar
Ummm lessee....
I had a rear passenger door start buzzing....
Thanks anyway, I'll study the manual....
Double E is offline
post #6 of 10 Old 04-09-2007, 08:38 PM
dunno513
I had a problem where the driver door wouldn't unlock all the time via the remote, but after being unlocked it wouln't restick until it sat for a few hours. Finally got tired of it and investigated it.
Found that the door lock mechanisms RUST. They really need attention before they get so bad that silicone, or grease won't help anymore. It was a relatively painless operation, the hardest part was getting all the release rods all reconnected and safety clips alligned correctly.
If you start to feel a less than smooth pop as the door opens, then you too have latches that need attention. We had one replaced under warranty , but for the aggrivation, it is just easier to do it myself as they show problems.
dunno513 is offline
post #7 of 10 Old 04-09-2007, 08:41 PM
dunno513
sounds like the child locks were activated.. good luck with that dilemma.. probably need a slim jim to tackle it
dunno513 is offline
post #8 of 10 Old 04-10-2007, 04:27 PM
Bob D.
Ummm lessee....
Not sure what the point of that post is...
Child door locks can only be manual activated on a WJ, and if that was the case the door can be opened from the outside.
Bob D. is offline
post #9 of 10 Old 04-11-2007, 10:35 AM
dunno513
not if the doorlock can't be unlocked electrically.. lol.. oops.. forgot that part of the dilemma eh?
dunno513 is offline
post #10 of 10 Old 04-11-2007, 06:35 PM Thread Starter
gpJeep
I paid 100 bucks for a new rear door latch and then
using the 1000 screw bit end set I got from princess auto found the
right bit torx 45 ? to take out the side door screw
after that 15 ,imutes and I had the new latch in there on the 3 torx screws and all is well ,
but now to fix that evil latch
a guy from auto club with a flat bar could probably open your fixated door
gpJeep is offline
Grande Cherokee door latch will not latch arory1@shaw.ca ZJ Grand Cherokee Forum 14 02-25-2015 09:36 AM
Broken Door Latch...PLEASE HELP... PIC adgjqetuo ZJ Grand Cherokee Forum 3 11-06-2013 08:57 PM
door latch fixmyjeep ZJ Grand Cherokee Forum 1 07-07-2009 08:57 AM
Problem with door latch 94 GC arory1@shaw.ca ZJ Grand Cherokee Forum 0 03-03-2009 09:29 AM
GC door latch, wont latch arory1@shaw.ca ZJ Grand Cherokee Forum 0 03-02-2009 08:33 AM
