WJ code P1476 - JeepForum.com
post #1 of 1 Old 08-07-2009, 08:22 PM Thread Starter
GrandHokie96
WJ code P1476
I know its the Governer Pressure Solenoid. Told my dad to have them replace the GPS, and the Governer Pressure Sensor, just in case. AND MAKE SURE they put ATF+4 in. I wanted to check his TPS, but couldn't get a good reading on anything. I know on the ZJ its the middle wire, and to check with key on engine off. Is it the same on the WJ?
Here are the symptoms...feels like its pulling out in 2nd sometimes 3rd gear. And it just had a transmission flush, which I understand could stir up some debris and cause this problem. Any other suggestions?
'98 Grand Cherokee 5.9L V8
-Stock suspension, 235/75R15 BFG AT's, AR767 rims with 4" BS - Fastman 52mm Throttle Body, K&N FIPK Gen 2, Kolak Exhaust, DMH Cutout, DT Headers, M1 Intake - 8300k 9004 Hi/Low HID's, 8000k H3 Off-Road Lamps - Rockford Fosgate P8002 and P4004 amps, 2x 12" Kicker CVR subs, Kicker SS56.2 components in Q-Logic kickpods, Front and rear Punch components, another set of components in the sound bar, 3600 watts total
GrandHokie96 is offline
Code 43 stageninja ZJ Grand Cherokee Forum 4 09-08-2009 09:40 AM
Engine Code help- Code 11 athomas08 ZJ Grand Cherokee Forum 3 05-07-2009 12:56 AM
AZC code 42 Arkansas_WJ ZJ Grand Cherokee Forum 2 04-08-2007 09:01 PM
Code 72 johnboy2814 ZJ Grand Cherokee Forum 1 02-19-2007 05:32 AM
Got Code 32 CaliforniaJeep ZJ Grand Cherokee Forum 3 02-14-2005 11:38 AM
