WJ: Cheapest shocks for 4" lift, What OEM Monroe shocks fit? - JeepForum.com
post #1 of 7 Old 06-29-2009, 12:15 AM Thread Starter
iluvtruenos
Very budget build.
I need something very basic, and preferably stiff.
I like the way Monroe shocks ride, and wanted to know what shocks can be modified to work in the WJ, or what other cheap shock there is out there.
If anyone knows anyone selling used stuff, please direct me that way and I'll kick you back something.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #2 of 7 Old 06-29-2009, 12:39 AM
xJoshxx
2012 WK
Black Diamonds People are going to say the cheapest Buy you get what u pay for.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 7 Old 06-29-2009, 12:56 AM
StellaTheZJ
I've been messing around with a YJ lately, and they have very long front shocks compared to XJs and ZJs. If you really want to buy Monroe, maybe front shocks to fit a YJ will be about what you need? You can press the bar pin into the new shocks from your old ones. Do WJs use bar pins?
Otherwise, scroll through the Monroe catalog until you find shocks with the specs you want. I'd start by looking for shocks with the correct ends, and then finding the longest ones that will fit when your suspension is fully compressed. Good hunting!
http://www.monroe.com/catalog/docume...engthSheet.pdf
StellaTheZJ is offline
post #4 of 7 Old 06-29-2009, 01:00 AM
xJoshxx
2012 WK
yes they use bar pins worthless pos's
2011 WK2 ORA2 sold
xJoshxx is offline
post #5 of 7 Old 06-29-2009, 01:27 AM Thread Starter
iluvtruenos
Actually, I've been searching that sheet relentlessly, and have come across two possible options.
Also, WJ and XJ have the same OEM shocks. For the front, at least.
post #6 of 7 Old 06-29-2009, 01:56 AM
StellaTheZJ
If you have searched relentlessly and found nothing, it's time to widen your search. You can easily modify the bottom ends of many shocks to take the bar pin, as you'd have to do for YJ shocks. I've done it recently, where I used a vice to press out the bar pins from my stock shocks and then install them in different shocks.
You can also install sleeves to shrink the bores in shock ends, or remove sleeves etc. If you get creative, you'll find a lot of options.
Have you improved your suspension in any way? If not, it's likely not the shocks that are limiting droop! It is probably the lower control arms, so you can't really use the full travel of a 4" longer shock! Typically, the factory shock is maybe 1/2" to 1" shorter than enough droop to bind the LCAs.
post #7 of 7 Old 06-29-2009, 02:05 AM Thread Starter
iluvtruenos
The two shocks that I found have to be modified using WJ bushings.
They're the closest ones that I think I can mount.
ZJ 2 - 3" lift with Monroe sensatrac/reflex shocks JohnnyZJ ZJ Grand Cherokee Forum 5 01-20-2010 02:22 AM
Cheapest place to buy 2"BB with shocks? cclark512 ZJ Grand Cherokee Forum 42 03-16-2009 01:55 PM
Monroe Shocks highryder08 ZJ Grand Cherokee Forum 9 07-25-2007 12:07 AM
cheapest place to buy lift+ shocks XJ99RedNY ZJ Grand Cherokee Forum 4 09-07-2006 12:47 PM
Monroe Shocks coolest_Stan ZJ Grand Cherokee Forum 27 03-08-2006 06:31 AM
