WJ caster with front double double cardan DS - JeepForum.com
post #1 of 4 Old 07-29-2009, 11:50 AM Thread Starter
doublejz
Ok, so I just put on my long arms and will be going take my WJ to get an alignment and plan on providing the specs I want. So I was planning on doing the following
Caster: +4
Toe-in: +1/16" to +1/8"
Then just making sure the rear axle is straight (same arm length)
but now I'm thinking since I have a double double cardan DS in the front I can probably get +6 to +7 caster without issues (or so I think).
Just curious what caster people are running that have the same style front DS.
TIA
04 WJ with some stuff -
doublejz is offline
post #2 of 4 Old 07-29-2009, 08:56 PM
sandman
+3 to +7 is acceptable. if your not having issues i would just leave it.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 4 Old 07-29-2009, 09:01 PM
gatorayde
Mines at 6* with only a single/double shaft at 4.5" of lift, no vibes.
gatorayde is offline
post #4 of 4 Old 07-30-2009, 11:48 AM Thread Starter
doublejz
Just changed all tie rod ends, drag link ends along with long arms... and well i don't have the caster set at all atm.. so I'm going to have issues :-p
doublejz is offline
Bad double cardan in front DS 97DCZJ ZJ Grand Cherokee Forum 26 12-19-2009 10:50 AM
front driveshaft double cardan? arsonist_bob ZJ Grand Cherokee Forum 12 03-21-2009 06:33 PM
Double Cardan front shaft --- Stock on 93 ZJ? CLNinja ZJ Grand Cherokee Forum 19 12-25-2007 09:59 PM
Front Drive Shaft (Double Cardan) Squeaking matt.x ZJ Grand Cherokee Forum 4 02-03-2007 11:47 PM
Double Cardan Front Drive Shaft Phil Gerard ZJ Grand Cherokee Forum 19 01-19-2006 04:10 PM
