WJ big leak in cargo after rain - JeepForum.com
post #1 of 5 Old 07-24-2008, 06:21 PM Thread Starter
steveadam87
My friend just bought a 2002 grand Cherokee and the past couples of days has been the first good rain since getting the car. We noticed some water in the trunk today and after looking more carefully there was about an inch of water in the spare tire compartment and most of the carpet in the cargo area was pretty wet. Has anyone had this problem before? Any help would be great thanks!
steveadam87 is offline
post #2 of 5 Old 07-24-2008, 06:28 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
My guess would be the rear hatch seal, if it has a a sunroof you may want to check that too.
xjfever is offline
post #3 of 5 Old 07-24-2008, 06:34 PM
gatorayde
The car eh?
gatorayde is offline
post #4 of 5 Old 07-24-2008, 07:01 PM
table
table's Avatar
2015 JK Wrangler
Check the rear window, liftgate & sunroof weather seals (if he has a sunroof). Ensure there's no accessory wires (like Sirius Radio antenna wire) crossing the seals. Ensure the seals are glued tightly to the body. Do some searches here or on JU for "replacing weather seals" or "leaky weather seals" ... etc.
Where was the water pooling? Was the Jeep on level ground?
2015 Anvil JKU | Sahara | Manual | 3.73
RIP: 2000 WJ | Initiated Destruct Sequence One | Code: 11A
table is offline
post #5 of 5 Old 07-25-2008, 12:19 AM
madrabbitt
madrabbitt's Avatar
i had a antenna wire running thru the seal on the bottom corner, and ended up with a puddle of water on the carpet in that area. So look for any breaks in the seals in the hatch, including window.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
Mystery rear cargo area leak kowboydmac ZJ Grand Cherokee Forum 19 11-12-2011 05:58 AM
2004 Grand Cherokee Rain Leak Help Needed Jagdpanzer ZJ Grand Cherokee Forum 5 01-11-2009 06:58 PM
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 05:58 PM
Small leak & cargo door WONT LOCK bigtb ZJ Grand Cherokee Forum 5 08-22-2006 12:17 PM
engine light - Evaporative Emission Control System Leak Detected (very small leak) sanboy ZJ Grand Cherokee Forum 3 03-14-2006 10:42 AM
