wj awd's any good? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > wj awd's any good?
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Jspec Suspension BLOW-OUT FEBRUARY ONLY!! HURRY UP!Income tax season is upon us. We got what u need
Unread 08-04-2009, 11:07 PM   #1
nwfjarhead
wj awd's any good?
are they prone to the same issues as the zj's? I have a zj now with the vc on its last leg and was wondering about the wj's? From what I remember reading they don't use the vc in them anymore? thanks
nwfjarhead is offline   Reply With Quote Quick reply to this message
Unread 08-05-2009, 07:41 AM   #2
comptiger5000
A WJ with Quadra-Trac II Full time 4WD or Quadra-Drive 4WD doesn't have the VC issue. Unless you abuse the TC or use the wrong fluid, they hold up fine.
By the way, they're technically still 4WD, not AWD. The only AWD WJs are any late model WJs with Quadra-Trac 1, which doesn't have neutral or low range.
comptiger5000 is offline   Reply With Quote Quick reply to this message
Unread 08-05-2009, 01:36 PM   #3
nwfjarhead
thanks for the input. as far as the awd. the only reason I called it such is because last time I referred to it as 4x4 I was flamed.
Unread 08-05-2009, 09:12 PM   #4
comptiger5000
In a technical sense, anything with a 4x4 low range is 4WD. The early NV249 (like your ZJ has) is debatable, being that low-range isn't locked.
Unread 08-05-2009, 09:55 PM   #5
GraKee99
Rapist Wit
GraKee99's Avatar
Whoever said that is an idiot. It is 4wd, Suburas are AWD. There is a difference.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 08-06-2009, 02:00 AM   #6
befumo
Thought it is AWD because its all time? Anyways got the 'AWD' transfer case in our WJ no problem 170k miles. ZJ AWD 120k and giving problems so just take that into consideration lol.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline   Reply With Quote Quick reply to this message
