wj awd's any good? - JeepForum.com
post #1 of 6 Old 08-04-2009, 11:07 PM Thread Starter
nwfjarhead
wj awd's any good?
are they prone to the same issues as the zj's? I have a zj now with the vc on its last leg and was wondering about the wj's? From what I remember reading they don't use the vc in them anymore? thanks
nwfjarhead is offline
post #2 of 6 Old 08-05-2009, 07:41 AM
comptiger5000
A WJ with Quadra-Trac II Full time 4WD or Quadra-Drive 4WD doesn't have the VC issue. Unless you abuse the TC or use the wrong fluid, they hold up fine.
By the way, they're technically still 4WD, not AWD. The only AWD WJs are any late model WJs with Quadra-Trac 1, which doesn't have neutral or low range.
comptiger5000 is offline
post #3 of 6 Old 08-05-2009, 01:36 PM Thread Starter
nwfjarhead
thanks for the input. as far as the awd. the only reason I called it such is because last time I referred to it as 4x4 I was flamed.
post #4 of 6 Old 08-05-2009, 09:12 PM
comptiger5000
In a technical sense, anything with a 4x4 low range is 4WD. The early NV249 (like your ZJ has) is debatable, being that low-range isn't locked.
post #5 of 6 Old 08-05-2009, 09:55 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Whoever said that is an idiot. It is 4wd, Suburas are AWD. There is a difference.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #6 of 6 Old 08-06-2009, 02:00 AM
befumo
Thought it is AWD because its all time? Anyways got the 'AWD' transfer case in our WJ no problem 170k miles. ZJ AWD 120k and giving problems so just take that into consideration lol.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
Quadra-Trac 1 questions, good or no good? 79bigmack WK Grand Cherokee & XK Commander Forum 15 12-19-2011 01:02 AM
want a good lift for a good price zjcopper ZJ Grand Cherokee Forum 11 03-28-2009 08:27 AM
Rustys Control Arms, good or no good? 99_WJjeep ZJ Grand Cherokee Forum 12 12-18-2008 06:07 PM
are you a good tech? (reallll good?) autobeamhotmail ZJ Grand Cherokee Forum 5 02-15-2007 05:42 AM
1994 grand cherokee good price and good base for offroading? DirtAddsHP ZJ Grand Cherokee Forum 8 01-24-2007 05:26 PM
