WJ automatic headlights going on and off at random - JeepForum.com
post #1 of 7 Old 06-21-2009, 07:46 PM Thread Starter
jeeplover93
I have a 1999 Grand Cherokee limited. I like to have the headlights set to automatic since I'm to lazy to turn them on myself, but now what happens is that the lights turn on and off at completely random times... Even when the car is turned off and locked.
How do I fix this??
jeeplover93 is offline
post #2 of 7 Old 06-21-2009, 09:24 PM
RyanSBenson
Sounds like your multifunction switch is on the fritz, from what I understand you need to buy a new one and replace it. Mine does the same thing, but I am too poor to fix it...
01' WJ Laredo Stock
96' XJ Sold
RyanSBenson is offline
post #3 of 7 Old 06-21-2009, 09:44 PM Thread Starter
jeeplover93
Yeah...even on eBay those switches are $80.
What do I have to do to install the switch?
Anyone know if those instructions are on WJJeeps?
post #4 of 7 Old 06-22-2009, 06:32 AM
Turbonut
http://www.wjjeeps.com/lamps/headlamps.htm#TROUBLE
I have a brand new switch, auto headlights, no fogs:
Airtex 1s1826-1999/2004-$50 shipped
Remove battery negative ground cable
Remove the screw that secures the lower tilting steering column shroud to the steering column multi-function switch mounting housing.
Unsnap the two halves of the shroud from each other and remove both.
Disconnect the instrument panel wire harness connector for the left multi-function switch from the switch connector receptacle.
Remove the 2 screws that secure the multi-function switch to the housing.
Remove switch.
Turbonut is offline
post #5 of 7 Old 06-22-2009, 12:33 PM Thread Starter
jeeplover93
I have fog lights, so that switch wouldn't work...
How much for a switch with fog lights?
post #6 of 7 Old 06-22-2009, 12:47 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
www.google.com
~James
ezflip is offline
post #7 of 7 Old 06-22-2009, 01:24 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
I actually have one for sale. Auto headlights, fogs, etc. PM me if interested.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
What's with the WJ's automatic headlights? indept ZJ Grand Cherokee Forum 7 04-21-2009 11:46 PM
automatic headlights problem H0miegwillikers ZJ Grand Cherokee Forum 9 02-05-2007 02:08 PM
Automatic Headlights are Flashing pfabricy ZJ Grand Cherokee Forum 16 08-30-2006 07:48 AM
Automatic Headlights mnjeepmale ZJ Grand Cherokee Forum 9 07-25-2005 03:35 PM
Automatic headlights flickering grovesj2 ZJ Grand Cherokee Forum 3 05-27-2005 07:04 PM
