WJ 4.7L Head gaskets? - JeepForum.com
post #1 of 2 Old 03-08-2009, 04:01 AM Thread Starter
Kramer H
Built and Supercharged 47
Kramer H's Avatar
Anyone done them before? i drained my oil today and guess what. time for head gaskets, which is weird because i was never overheating.. anyhow, how hard are they to do? as simple as pulling heads off, slapping new gaskets on and off we go? (check clearences on the heads with straightbar and feelers to make sure i dont have to have them decked) other than that is it pretty straightforward?
And another question, if i swapped a 02 and on H/O motor in my 01, would i have to change anything other than the motor? (wiring, computors, sensors)? or can i just swap in the cams and the intake manifold?
THANKS
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #2 of 2 Old 03-08-2009, 08:23 AM
nierace
nierace's Avatar
2003 WJ
Should be able to just throw in the new head gasket and go...
You should be able to swap in a HO motor, but you might need to steel the pcm from the donor, I'm not sure about that you may wanna check with 10achik. However if you never over heated you should be fine.
An interesting idea that I had if you've got a dead motor would be to get a 4.7 out of a 2008 WK (305hp vs. 265 and better MPG) it would definitely take a bit more work but if you're already doing a engine swap...
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
Is it true...about head gaskets hrtbrk1 ZJ Grand Cherokee Forum 16 12-30-2009 11:28 AM
CICCARELLI gaskets kedron ZJ Grand Cherokee Forum 2 10-19-2009 04:42 PM
Changing oil pan gaskets? gmartin1215 ZJ Grand Cherokee Forum 3 02-08-2009 03:10 AM
Gaskets been replaced, still no joy. kopite77 ZJ Grand Cherokee Forum 11 11-29-2007 02:34 AM
Changing out Head Gaskets newnorth ZJ Grand Cherokee Forum 4 09-25-2005 07:50 PM
