WJ 4.7 belt squeal? - JeepForum.com
post #1 of 9 Old 01-21-2009, 02:07 PM Thread Starter
tufmar
WJ 4.7 belt squeal?
Trying to track down the latest squeal on my '02 WJ 4.7 (80K miles). Its basically a typical belt squeal that kind of resembles a tea kettle sound, only not as loud. Now it doesn't make the sound all the time, kind of sporadic but I have narrowed it down to this: from a dead stop under acceleration it will trigger the squeal and last for several seconds after you reach your cruising speed. As soon as you apply brakes or come to a stop, the sound completly fades away to nothing. Also on initial start up of the vehicle or idle, it does not make the sound. Any ideas, idler pulley, serpentine belt??
93 YJ - 4.0 2" BDS 1" BL 33's
98 ZJ - 5.2 Limited 2" BB 31's
02 WJ - 4.7 Laredo 242 TC 3" IRO 245/75's
tufmar is offline
post #2 of 9 Old 01-21-2009, 02:14 PM
tbm5690
It's a leak in the turbo lines.
Seriously though, what shape is the belt in? Check the tensioner and pully for play.
2001 Grand Cherokee Laredo S/A package 4.7L V8
K&N high-flow filter, Airaid MIT, Flowmaster 50 catback
tbm5690 is offline
post #3 of 9 Old 01-21-2009, 02:14 PM
jeep95xj
1995 XJ Cherokee
80K miles on the stock belt? If so yea it's way past time. I change my belt along with tranny fluid and t-case fluid every 25-30K miles. Diff fluid twice a year. Most people over look all those things.
jeep95xj is offline
post #4 of 9 Old 01-21-2009, 02:21 PM Thread Starter
tufmar
I doubt if its the original belt, but you never know? I purchased the vehicle with roughly 48K, so its a possibility bc I have never replaced it to date. Now I am no expert on serpentine belts, but there are no obvious cracks or gouges. When you say check for play in the tensioner, exactly how does one do that? Or should I say how much play, if any, should it have?? In the meantime, I'm gonna go ahead and replace the belt, its cheap enough and hopefully kills the noise.
tufmar is offline
post #5 of 9 Old 01-21-2009, 03:19 PM Thread Starter
tufmar
Here is a dumb follow up question. To remove the belt I know you take your 15MM and rotate the tensioner clock-wise and the belt pops off. But in terms of tightening it, how is that done? Or does the automatic tensioner do what it says an automtically adjust to the belt? I am not used to the automatic tensioner, Im used to the manual adjustment like on my '93 YJ.
tufmar is offline
post #6 of 9 Old 01-21-2009, 03:23 PM
jeep95xj
1995 XJ Cherokee
You dont tighten it. Put it back on the same way you took it off you have an automatic belt tensioner. As long as the tensioner is not super easy to move and locks toghtly against the belt your good. While the belt is off turn the water pump, alt, power steering pump, ac compressor and anything else you see. Make sure they all move nice and smooth.
jeep95xj is offline
post #7 of 9 Old 01-21-2009, 03:42 PM Thread Starter
tufmar
Easy enough, thanks for the tips...
tufmar is offline
post #8 of 9 Old 07-31-2016, 11:09 AM
stauffdaddy
Hey Guys, I bought my first Jeep last saturday so needless to say I am new to this whole thing. its a 2002 WJ with a 4.7. (forgive me if this topic has already been beat to death I have yet to master navigating the forums so work with me haha) So it rained here a few days ago and the belt started making a squealing noise so I put a new one on there. The squeal went away for a few days but 2 days ago when i started it it started making a chirping noise when it was idling and when I would drive it (the chirping would increase when i would accelerate) and after a while the chirp would kind of go away. Yesterday when i started it I popped the hood to see where exactly it was coming from, i was guessing the tensioner pulley but it sounded like it was coming from either the power steering pulley or the generator pulley. The chirp doesnt change when i turn or anything, only when I accelerate and just drive. Any idea on what could be going on? I appreciate any tips and responses
stauffdaddy is offline
post #9 of 9 Old 07-31-2016, 11:12 AM
kg6mov
Hears the voices
kg6mov's Avatar
Welcome to the forum!
In the time since this thread was shiny and new the Grand Cherokee forum has been split into individual forums for the different models (ZJ, WJ, WK, WK2). Unfortunately all the old posts are still in the ZJ forum.
You will get better help for you WJ (1999-2004 Grand Cherokee) by posting in the forum for that model: http://www.jeepforum.com/forum/f310/
It's possible that some moisture got into the engine bay and gave a bearing on the pump or alt that was on its way out that last little kiss of death.
kg6mov is offline
belt squeal - after 2 belts alivenkickin28 ZJ Grand Cherokee Forum 35 03-16-2012 06:11 PM
Obnoxious Belt Squeal after Replacement ddeadserious ZJ Grand Cherokee Forum 16 04-23-2009 10:26 PM
Belt Squeal 4.0 200KGrand ZJ Grand Cherokee Forum 1 10-08-2008 01:40 PM
Belt squeal on 4.7 HurriJeff WK Grand Cherokee & XK Commander Forum 3 02-17-2008 07:13 AM
Squeal on start up, not the belt CruiserClass ZJ Grand Cherokee Forum 1 01-09-2008 06:14 PM
