WJ 30,000 mile maintenance - who done it? - JeepForum.com
post #1 of 8 Old 02-20-2005, 07:54 PM Thread Starter
DrEvil
I hit the 30k mark in my 03 limited. I did my normal 3000 mile oil change, but noticed in the maintenance guide it suggests replacing the plugs and draining and refilling the transfer case (for Quadra-Trac models). I have 2 questions - first of all, I have QuadraTrac II - was there another transfer case just called QuadraTrac? In other words, do I need to change my transfer case fluid?
Secondly, what did the dealer charge for the 30000 service for those of you who had it done?
2003 Jeep Grand Cherokee Limited
2006 Volkswagen Passat 2.0T
1969 Oldsmobile 442
DrEvil is offline
post #2 of 8 Old 02-20-2005, 07:58 PM
rowdy1
rowdy1's Avatar
30K service
This maintenance schedule is probably standard for all Jeep models.A jiffy lube can do the drain and refill for you.its no big deal
rowdy1 02 GC Laredo
rowdy1 is offline
post #3 of 8 Old 02-20-2005, 10:04 PM
cherokee04
cherokee04's Avatar
2005 WK
I changed the fluid in my Quadra-Trac II transfer case this weekend -- only took a few minutes, other than the time I let it sit an drain all the fluid out of it. I picked up a 10m allen wrench socket from sears, and both the fill and drain plugs came out easily.
By the looks of the fuild that drained out my tranfer case, I'd say you need to change it at 30K miles -- I was surprised how dark that fluid was. I'm glad it has clean fluid in there.
cherokee04 is offline
post #4 of 8 Old 02-20-2005, 10:29 PM Thread Starter
DrEvil
So it sounds like I should change my transfer case fluid and I can do it myself. That's conforting. What about the spark plugs?
1969 Oldsmobile 442
DrEvil is offline
post #5 of 8 Old 02-20-2005, 10:38 PM
cherokee04
cherokee04's Avatar
2005 WK
You will find changing the tranfer case fluid very easy -- just make sure you pick up a pump to pump the fluid into the case -- it is much easier than trying to get a funnel to pour it in the fill hole. You'll find the pump useful when you change the differential fluid, too.
The spark plugs are also easy to change -- there is a whole thread on changing them. Just make sure you have the right plugs for your engine, and make sure they are correctly gapped. When removing the old one, make sure you identify which plug wires go to which plug, so you don't screw up the firing order, and make sure the area is cleaned around them so no garbage falls into the cylinder when you pull out the plug.
post #6 of 8 Old 02-20-2005, 10:39 PM
rowdy1
rowdy1's Avatar
If you've never done this kind of work before,or just don't feel comfortable doing it take it to a garage.A stripped plug hole can put a kink in your weekend!
rowdy1 02 GC Laredo
rowdy1 is offline
post #7 of 8 Old 02-21-2005, 12:44 AM
laphan
I thinks its a good idea to change transmission fluid and filter and axle fluid. I'm assuming you never replace any fluid since you got it new (there might be metal flakes on your fluid from gears and clutches from new unit got broken in).
98 ZJ, 4.0L I6, 42RE, NP242.
Upgrades: mopar skid plates, mopar tow hitch, Hayden transmission cooler, OME SS, DT8000 pre-runner shocks, Kevin's Radiator Support, 2" BB, Bridgestone Dueler A/T revo.
laphan is offline
post #8 of 8 Old 02-21-2005, 10:10 AM
cherokee04
cherokee04's Avatar
2005 WK
I was amazed at the junk attached to the magnet on the rear differential plate when I pulled that off. It took a while to get all that stuff off, and out from under the magnet -- I used an air hose to blow it out and get it good and clean. The fill plug magnet on the front differential had a few shavings, but nothing like the rear axle.
But, when I changed the two transmision filters, I didn't see anything on the pan as I had expected.
300,000 mile pic driabyor ZJ Grand Cherokee Forum 83 06-28-2012 06:06 PM
30k mile maintenance adgjqetuo ZJ Grand Cherokee Forum 9 01-03-2009 04:38 PM
2005 Limited W/Hemi 60,000 mile maintenance Codee WK Grand Cherokee & XK Commander Forum 1 01-03-2008 02:40 PM
12000 mile scheduled maintenance guyshmee WK Grand Cherokee & XK Commander Forum 6 03-11-2007 11:03 PM
60,000 mile maintenance Vectork39 ZJ Grand Cherokee Forum 4 07-18-2005 09:39 PM
