Wits end! - JeepForum.com
post #1 of 7 Old 10-18-2013, 05:55 PM Thread Starter
colebe
Wits end!
Hello all! I am new to this forum but I am at my wits end with my '97 ZJ.
Here's the shortest version I can give.
Right front caliper froze recently causing steering wheel to turn violently back and forth until I was able to free the piston by driving on the highway rumblestrip.
Caliper boot was melted and pads/rotor were shot. Pads showed signs of wearing unevenly front to rear.
Since this event I have a steady pull to the right which gets really bad when braking. My wife will no longer drive her until fixed!
What's been done...
I have personally replaced all of the front brake components - pads, rotors, calipers, flex hoses. I have cleaned and lubed the slide rails. All 4 wheels have been bled to flush all old fluid. Wheel alignment has been checked good. Tires have been rotated. All front end suspension/steering components look good visually. No obvious signs of damage or unusual wear. Brake pressures have been checked good. Go to full pressure evenly and release evenly. Driving at 30 MPH, go to neutral, still pulls. Driving at 30 MPH, turn off ignition, still pulls.
I consider myself an above average mechanic having done all my own maintenance for 30 years. This one has got me stumped. I apologize for the length of this post. Any knowledge shared will be greatly appreciated.
colebe is offline
post #2 of 7 Old 10-18-2013, 06:28 PM
970001zj
tire wear/bearing/alignment/wear on parts like bushings
970001zj is offline
post #3 of 7 Old 10-18-2013, 07:56 PM
ieattacos
Ball joints
ieattacos is offline
post #4 of 7 Old 10-18-2013, 08:19 PM
970001zj
that too but i thought an above average mech wouldve caught that one
970001zj is offline
post #5 of 7 Old 10-19-2013, 04:44 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Divots in caliper slides on knuckle. You can see them in post#3 of this thread.
http://www.jeepforum.com/forum/f13/c...build-1518536/
Originally Posted by HighLonesome
coralman is offline
post #6 of 7 Old 10-19-2013, 06:49 AM
kbranderhorst
something easy and cheap too try would be swapping the front tires left too right and see if that helps i have had that happen too me at work before do all new brakes and still have a pull ended up being a tire issue good luck other than that like said above could be a worn front end part or some type of restriction in the hydraulic system ex: master cylinder abs or proportioning valve good luck
kbranderhorst is offline
post #7 of 7 Old 10-19-2013, 06:50 AM
kbranderhorst
like said above as well the steering knuckle divots are a very good possibility on a jeep i had too fill mine in with weld 2 weeks ago
