wiring my lights need help! - Page 3 - JeepForum.com
post #31 of 35 Old 09-30-2009, 05:12 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
just figured it out wow im an idiot, the screws I mounted the lights with in the back were pushing on the power wire for the lights so it would cause a short and cause the fuse to blow each time. fixed it by putting some electrical tape over the screws, works fine now. Now I feel like an expert at wiring these since i have spent so much time looking into and wiring these things. glad they work now
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline
post #32 of 35 Old 09-30-2009, 05:30 PM
crenshinivon
You should probably replace that section of wire as well. That could be a short waiting to happen. Shorts are never good. It is a possibility that next time it won't blow the fuse, instead it just might drain your battery.
crenshinivon is offline
post #33 of 35 Old 09-30-2009, 05:34 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
I did change the section of wire with the fuse in it, put a new inline fuse in there. works awesome
post #34 of 35 Old 09-30-2009, 06:39 PM
FDWJ
glad to hear you got that a squared away, its really important to make sure your wires are good and run correctly. i nearly burnt down my CJ cuz i half-***ed the wiring in it. I learned my lesson and pay close attention to wiring things in my WJ now.
'04 WJ 4.0 Select-Trac with Rusty's 2.5" Lift on 31"s
Firefighter Jeep Club member #99
FDWJ is offline
post #35 of 35 Old 10-01-2009, 12:47 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
yeah, my old jetta the whole dash caught on fire because all of the wiring in it was screwed up so bad, not from me it was just old and there were shorts everywhere in it. I wanted to be sure these lights were hooked up well, because i dont want m jeep to catch on fire
Need Help Wiring Lights on RR Pbux690 ZJ Grand Cherokee Forum 5 02-24-2009 10:16 PM
Roof lights wiring routing trailblazr81 ZJ Grand Cherokee Forum 4 01-03-2009 10:52 PM
Wiring Roof lights ?? RRAM ZJ Grand Cherokee Forum 7 11-10-2008 09:29 AM
wiring in aux. lights?? tcris3 ZJ Grand Cherokee Forum 5 04-15-2008 06:35 PM
Wiring Into Reverse Lights mr_user ZJ Grand Cherokee Forum 7 11-25-2005 06:52 PM
