wiring my lights need help! - Page 2 - JeepForum.com
post #16 of 35 Old 09-29-2009, 02:38 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Wait for photobucket to update the link. They are taking for ever. There should be one more lead from the switch to the battery 12+ and one more from the relay to the battery.
~James
ezflip is offline
post #17 of 35 Old 09-29-2009, 02:43 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
what about the wire to the fusebox?
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline
post #18 of 35 Old 09-29-2009, 02:46 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
and my common ground from the lights does not go back to the relay it just goes to the body is this ok?
post #19 of 35 Old 09-29-2009, 02:48 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
the lights are hella 500's by the way
post #20 of 35 Old 09-29-2009, 02:49 PM
LordHobbit
Ground to the body all the time. The longer the ground wire the more problems you'll have. What is this wire to the fusebox? Why are you wiring anything to the fusebox?
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #21 of 35 Old 09-29-2009, 02:51 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yes that is better actually.
~James
ezflip is offline
post #22 of 35 Old 09-29-2009, 02:52 PM
LordHobbit
Here are some instructions: http://www.hella.com/produktion/Hell...structions.pdf
Maybe you already have these.
post #23 of 35 Old 09-29-2009, 02:56 PM
WiCkeDuDe
WiCkeDuDe's Avatar
There is no reason to run the battery to the switch. Your using the switched power to only turn on the lights when the ignition is on. You dont want constant power to it.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #24 of 35 Old 09-29-2009, 02:58 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
I am wiring from the switch to the fusebox, because this is instead of wiring to the highbeams, so I can have the highbeams and lights on at the same time
Jeepin.com: Hella 500's
this is what I searched for the help
post #25 of 35 Old 09-29-2009, 02:58 PM
steveheibel
steveheibel is offline
post #26 of 35 Old 09-29-2009, 03:07 PM
LordHobbit
No No No No Get an auxillary switch. Forget the fusebox, fuse the hot line from the battery to your auxillary switch and wire it up according to the hella instructions. Wiring to another fuse that already has something hooked to it is bad practice.
post #27 of 35 Old 09-29-2009, 03:19 PM
steveheibel
post #28 of 35 Old 09-29-2009, 03:47 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
yeah, its that bottom supply wire that I am runing to a blank spot on the fuse box. other than that I think i have the exact same setup
post #29 of 35 Old 09-30-2009, 02:32 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
wired it up exactly as the hella instructions said, but keep blowing fuses and no lights excpt the light on the switch. I even changed it and ran a wire to the lights. please help!
post #30 of 35 Old 09-30-2009, 02:46 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
bump!!! please anyone have any clue what is wrong?
Need Help Wiring Lights on RR Pbux690 ZJ Grand Cherokee Forum 5 02-24-2009 09:16 PM
Roof lights wiring routing trailblazr81 ZJ Grand Cherokee Forum 4 01-03-2009 09:52 PM
Wiring Roof lights ?? RRAM ZJ Grand Cherokee Forum 7 11-10-2008 08:29 AM
wiring in aux. lights?? tcris3 ZJ Grand Cherokee Forum 5 04-15-2008 05:35 PM
Wiring Into Reverse Lights mr_user ZJ Grand Cherokee Forum 7 11-25-2005 05:52 PM
