Wiring ID Problem - JeepForum.com
post #1 of 6 Old 09-09-2013, 09:29 AM Thread Starter
wbthompsonco
Wiring ID Problem
1998 Grand Cherokee 4.0L. While underneath it today, looking at exhaust components I need to replace, I spotted a wire that apparently rubbed on the driveshaft right behind the transfer case until it work right through. It's one of 2 wire assemblies that come across the top of the transmission - one wire connects near the top of the transfer case, and the other goes to a connector and then attaches to the body just to the right side of the driveshaft.....and then is gone, worn away. Does anyone know what this wire assembly is for? I don't even see where the other end of it could be, so I think at some point the driveshaft caught a good-sized length of it and ripped it off. I know that reverse lights and the rear wiper don't work. No fuses are blown under the hood or in the fuse panel in the passenger compartment.
wbthompsonco is offline
post #2 of 6 Old 09-09-2013, 02:04 PM
Oldfrog
2007 WK
Sounds like the O2 sensor at the Cat. It's known for wrapping around the drive shaft, shorting and blowing a fuse in the PDC under the hood, which will make keep it from running.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 6 Old 09-09-2013, 06:15 PM
ZeeJay1997
what color is the wire and tracer?
ZeeJay1997 is offline
post #4 of 6 Old 09-09-2013, 06:36 PM
xcaliber81
No reverse lights? How about the NSS?
xcaliber81 is online now
post #5 of 6 Old 09-13-2013, 01:20 PM Thread Starter
wbthompsonco
followup question
Forgive me, but what is NSS?
post #6 of 6 Old 09-13-2013, 01:51 PM
newfieZJ
Wire on the t-case would be the shift indicator , wire attaching to the body by a small plastic clip would be the downstream O2
NSS= neutral safety switch
on that wiring harness is also the t-case speed sensor , trans speed sensor , trans main bus plug in , upstream O2 , and CPS (crank position sensor)
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
