Wiring in Hellas.... - JeepForum.com
post #1 of 22 Old 05-29-2009, 08:50 AM Thread Starter
ZJPunk98
Well I just installed my ARB bumper last night and I'm looking to get some hella 500s or 700s to run as some driving lights on the bumper. I would like to run these lights on the factory fog light switch.
What I need to know is if the factory wiring could handle 2 100watt lights or should I used the factory wiring as a switch to a relay and run a power line from the battery to the relay and then the lights.
I think with 2-100watt hellas... running a 40amp fuse and relay, then slitting the source line from the relay to the lights. Is this a good plan? I'll run either 10 or 8 gauge. I think 10g should be fine.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #2 of 22 Old 05-29-2009, 09:50 AM
besthaticouldo
use the factory wiring to relay the hellas...i doubt they'll hold 100 watts.
besthaticouldo is offline
post #3 of 22 Old 05-29-2009, 09:53 AM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
I would use 8 ga., 10 is good for 15 amps and you are a little above that with 2-100 watt lights
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
YJMCBoy is offline
post #4 of 22 Old 05-29-2009, 10:42 AM Thread Starter
ZJPunk98
Thanks guys.... I'll use the factory wiring to the relay. I figured that was the best way to go. i'll make sure to use 8ga wiring. Should I be running a 20amp fuse with 40 amp relays? instead of a 40 amp fuse? I'm not sure of the math here. If I knew the formulas.... i would figure it out. Maybe i'll google them.
Also I was just thinking, maybe i should run some rectangle hellas... to match the jeep. I know a lot of people use the round ones, but i figure the zj is fairly sqaure. Your thoughts?
Erik
ZJPunk98 is offline
post #5 of 22 Old 05-29-2009, 10:51 AM
MeWJWifeZJ
Ick is my opinion. The Hella 500's we ran on the ZJ before it rolled looked great (See avatar) now they are on my WJ awaiting a new cow catcher for her ZJ
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #6 of 22 Old 05-29-2009, 10:58 AM Thread Starter
ZJPunk98
alright... thanks
Erik
ZJPunk98 is offline
post #7 of 22 Old 05-29-2009, 11:07 AM
Bama_WJ
Bama_WJ's Avatar
(2 x 100W) / 12V = 16.67A
Run a 40A relay and a 20A fuse.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #8 of 22 Old 05-29-2009, 11:12 AM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
Hey man, I would probably use a 20A fuse, the only problem I can think of is if inrush current at initial startup is higher than that you may have nuisance fuse blowing. I am not an electrician but I typically size my fuses for 125% of amp draw (as long as it doesn't exceed wire capabilities) 8 ga wire is good for 24 amps. That being said if the 20A fuses pop due to inrush you can get away with a 25A fuse but don't go any larger than that. If you run 40A relays and 40A fuse and something is wrong with the lights where they start using more current, you have the potential of burning the rig down due to too much current through your conductors. (8 ga) Besides protecting your equipment, you want to protect your wiring too with fuses/breakers.
edit: Bama beat me to it!
YJMCBoy is offline
post #9 of 22 Old 05-29-2009, 11:38 AM Thread Starter
ZJPunk98
Thanks guys. Still planning things out... maybe i'll try and draw my plans up and post them here later so you can all see them and let me know what you think.
Erik
ZJPunk98 is offline
post #10 of 22 Old 05-29-2009, 12:02 PM
Bama_WJ
Bama_WJ's Avatar
Well, at most electronics stores you can by either fast blow or slow blow type fuses. I would recommend a slow blow fuse as it would be a little more forgiving of a transient current like when you turn on the lights. A fast blow fuse will pop the split second it passes 20A. But a 25A fuse would probably work as well.
Daniel
Bama_WJ is offline
post #11 of 22 Old 05-29-2009, 12:16 PM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
That's a good point to make and a very valid one.
YJMCBoy is offline
post #12 of 22 Old 05-29-2009, 12:20 PM
Mickey_D
And I call myself an electronics tech.
Very good point and one I should have thought about long ago.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #13 of 22 Old 05-30-2009, 07:25 AM Thread Starter
ZJPunk98
when i cut the factory wiring to remove the fog lamp, should leave the wiring as an open or close circuit? This is pretaining to the one side of the factory wiring which I will not use for the relay.
Erik
ZJPunk98 is offline
post #14 of 22 Old 05-30-2009, 09:25 AM Thread Starter
ZJPunk98
Ok... I need help deciding what lights to get.
I really like these Hella Rallye 4000 Xenons, but they are way to expensive
How about these rallye 4000
or these Optilux 1900s
or just go with the every day 500s or 700s?
The more i look, the more indecisive i get with all the choices. I'm looking for 1 or 2 sets for my ARB bumper, which one set will be used during driving.
Erik
ZJPunk98 is offline
post #15 of 22 Old 05-30-2009, 09:43 AM
Mickey_D
As for the unused wire, there should be a plug somewhere back behind the grille. Just unplug the side you won't be using and zip tie it up out of the way of everything.
As for the lights? I can't really tell you. I've got the 700FF's on the front of mine and love the hell out of them. And I'm using the stock wiring (700FF's are 55W).
________________
#4
Mickey_D is offline
Wiring Hellas to factory fog wiring? ddeadserious ZJ Grand Cherokee Forum 2 02-12-2009 03:02 PM
What do you think about Hellas on front hevans1 ZJ Grand Cherokee Forum 2 02-26-2008 06:23 PM
hellas wired up sandman ZJ Grand Cherokee Forum 13 12-08-2007 05:07 PM
WJ- Silverstars and 2 Hellas or 4 Hellas only? JayIV ZJ Grand Cherokee Forum 14 09-26-2006 08:01 AM
Hellas 01grander ZJ Grand Cherokee Forum 4 01-12-2005 09:25 AM
