Wiring Harness Help? 5.9 v8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Wiring Harness Help? 5.9 v8
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-25-2015, 02:36 PM   #1
AshleyAnnZJ
So while cleaning leaves out of my 5.9's engine compartment I found this plug on the wiring harness buried in the leaves with some clear tape on it. Its behind the fuse box on the passenger side. Its got the male/female connections, but the wires are missing from one end. Everything is running fine so far as I know, I cant find anything loose in the compartment that this might have belonged to this.
Any ideas what this is?
Ashley in SC with a 98 ZJ 5.9
3.5" IRO Front to Rear Lift
Instagram for pics AshleyZJ5.9
AshleyAnnZJ is offline   Reply With Quote Quick reply to this message
Unread 03-25-2015, 02:54 PM   #2
Timo_90xj
Timo_90xj's Avatar
It's the test port for your E-fan system.
I'd need to check out the pins which is which, but you can test the e-fan operation by pulling the dummy plug off and doing some measuring and/ or jumper-wire things. Don't play around with it too much, if you connect certain two terminals, you will get a short, a mini-fuse in the PDC will burn, and your Jeep won't fire-up. Don't ask me how I know..
edit: Found it. I copied the e-fan wire harness schematic to my picture archive site:
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 03-25-2015, 03:01 PM   #3
AshleyAnnZJ
Ok so I'll just shove it back into the spot I found it. Thanks! I was all over that jeep looking for free wires last night
Unread 03-25-2015, 03:08 PM   #4
Timo_90xj
Timo_90xj's Avatar
You were doing a bit of ghost- hunting then
As for empty wire harness connectors: most vehicles have from a few up to more than a dozen empty connectors all around the vehicle - vehicle manufacturers tend to make only one wire harness version per vehicle body type, so that they can install the wire harness for every one of those vehicles, no matter what the customer wants on it. So, depending on your trim level and amount of optional items/ features ordered, there may be a lot of empty connectors, or almost none.
On the 5.9 Grand Cherokees, most wire harness connectors are in use because our niners were top-of-the-line, and included most of the stuff that were optional on many other ZJs
Unread 03-25-2015, 03:41 PM   #5
AshleyAnnZJ
Interesting - years of working on nissans and don't recall ever seeing one. Thanks for wiring harness diagram that'll come in handy I'm sure
Unread 03-25-2015, 03:58 PM   #6
Timo_90xj
Timo_90xj's Avatar
There may have been hidden ones inside the dash, door panels, under the seats, etc.. not all vehicle manufacturers do it the way Jeep does, but most do. It depends a lot on their harness design though.
5.9 e-fan wire harness is fully independent from the rest of the engine wire harness, but if you ever need to pull it completely out, it's a major pain. I needed to do that last year for thorough inspection at the garage table, because I had some issues with the low speed not working.
Unread 03-25-2015, 06:04 PM   #7
xcaliber81
1994 ZJ
Also in that location on 98 was the auto headlight module.
xcaliber81 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 01:27 AM   #8
Timo_90xj
Timo_90xj's Avatar
What OP posted, is the 5.9 e-fan diagnostic connector, nothing else.
Unread 03-26-2015, 08:38 AM   #9
xcaliber81
1994 ZJ
Im not saying it wasnt.
5.9l grand cherokee zj , wiring harness
