wiring diagram.....remote starter install - JeepForum.com
post #1 of 17 Old 11-16-2005, 02:50 PM Thread Starter
buz0340
hi,
i was researching how to install a remote starter on my 95' grand cherokee and wanted to look at a wiring diagram. maybe some one could help me find one or any material that might help me out? has anyone attempted this project?
thankyou,
brian
buz0340 is offline
post #2 of 17 Old 11-16-2005, 03:12 PM
guango88
Air Trans
guango88's Avatar
it all depends on the brand that you are using, if you know call the company or go in the web, and get some tech support.
ONE ABOVE ALL
guango88 is offline
post #3 of 17 Old 11-16-2005, 07:33 PM
RobertTF
RobertTF's Avatar
I did this in my parents dodge ram and wow was that a PITA. It also inluded keyless door entry and an alarm. I think the instructions with the unit were pretty usefull. Get yourself an auto voltage tester at hardware or auto store. It will come in handy!
2001 4.7l Limited WJ
IRO 6.5" Critical LA, Lonestar Incline Bumper, XRC-8000 Comp Winch, 33" BFG All-Terrains, and a long list of other stuff.
RobertTF is offline
post #4 of 17 Old 11-16-2005, 07:34 PM
mailforjon
mailforjon's Avatar
2005 WK
snoop around.....
http://www.installdr.com/
http://www.the12volt.com/default.asp?
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
post #5 of 17 Old 11-16-2005, 07:35 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
I've done one, and have decided that I would rather go outside in the cold and start my vehicle than attempt to wire another. What a PITA!!!!
You'll have to get instructions from the manufacturer. Different companies use different color wires.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #6 of 17 Old 11-20-2005, 09:54 PM
jefferskn
Jeep || Grand Cherokee || 1993 - 1995
Remote Starter Wiring Colors and Notes
Function Vehicle Color Location
Start: YELLOW/DARK BLUE
Ignition #1: DARK BLUE/GRAY IGNITION SWITCH HARNESS
Ignition #2: ORANGE/BLACK IGNITION SWITCH HARNESS (HEAT-A/C)
Ignition #3: N/A
Accessory: BLACK/WHITE IGNIITON SWITCH HARNESS (RADIO/WIPER)
Brake Light: WHITE/TAN (+) SWITCH ON BRAKE PEDAL BRACKET
Tach Signal: GRAY/WHT OR GRAY/BLACK AT COIL OR PCM *
Parking Lights: DARK BLUE/RED (+) HEADLIGHT SWITCH OR AT FUSE BOX
Headlights: TAN/BLACK (+) HEADLIGHT SWITCH OR BEAM SELECT SW.
Diesel Glow Plug:
Clutch Bypass Wire:
Notes: * Powertrain Control Module (PCM) Located In Passenger Rear Corner Of Engine Compartment Near A/C Receiver/Dryer. Tach Wire At Pin #19, GRAY/L BLUE At Pin #43 Can Also Be Used For Tach.
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts: RED/WHITE FUSED AT # AMP AND PINK/BLACK FUSED AT # AMP
OEM Alarm Disarm: VIOLET/YELLOW (-) DRIVER KICK PANEL
OEM Horn: GRAY/ORANGE (-) STEERING COLUMN HARNESS OR AT RELAY
Power Lock: ORANGE/VIOLET DRIVER'S KICK PANEL **
Power Unlock: PINK/VIOLET DRIVER'S KICK PANEL **
Trunk Release: ORANGE/BROWN (+) LIFT GLASS RELEASE (AT SWITCH)
Alarm Input Wire: YELLOW (-) DRIVER KICK PANEL OR COURTESY LIGHT
Notes: ** See Note #202 - Positive Pulse Door Lock Diagram.
JEEP GRAND CHEROKEE 4DR STN UTY LAREDO LTD SE 1996-97
Alarm Notes Wiring Location
Constant Power : RED/WHT IGNITION SWITCH HARNESS
Ignition Power : DK.BLU/GRY IGNITION SWITCH HARNESS
Starter Kill : YEL/BLU OR YEL IGNITION SWITCH HARNESS
Door Trigger : YEL (-) DRIVER'S KICK PANEL
Trunk Trigger : N/A WORKS WITH DOME LIGHT
Parking Lamp : BLU/RED LEFT OF STEERING COLUMN OR LIGHT SWITCH
Power Lock : 5/WIRE IN DRV DRV DOOR ORN/VIO"L" AND PNK/BLK"UL"
Power Unlock : AND PAS DOORS PASS DOOR BLK/WHT"L" AND PNK/BLK"UL"
***********TEK NOTE!***************
This is a dual 5 wire reverse door lock system and must be
approached at both the driver and passenger doors.
Remote Start Wiring Location
Starter Wire : YEL/BLU OR YEL IGNITION SWITCH HARNESS
Tach Sensor : GRY/WHT (-) AT COIL "BEHIND COOLANT BOTTLE"
Ignition (1) : DK.BLU/GRY IGNITION SWITCH HARNESS
Ignition (2) : RED/BLK IGNITION SWITCH HARNESS
Accessory : BLK/ORG IGNITION SWITCH HARNESS
Brake Switch : WHT/TAN AT BRAKE SWITCH
Speed Sensor : WHT/ORG 8000 IN WIRE HARNESS FROM TRANSMISSION
Accessories Wiring Location
Window Up : LF:LT.BLU RF:BRN/WHT LR:BLU/WHT RR:GRY/BLK DOORS
Window Down : LF:WHT RF:VIO/WHT LR:RED/BLK RR:GRN/WHT DOORS
Trunk Release : TAN/BLK (-) DRIVERS KICKPANEL
Horn (Relay) : GRY/ORN (-) AT STEERING COLUMN
Head Lamp : TAN/BLK AT LIGHT SWITCH
Wiper : BRN/WHT AT STEERING COLUMN
Radio Specifications
Type : DIN
Depth : 7 3/4"
Kit : YES
Antenna Information
Type : N/A
Adapter :
Radio Notes *
Memory : RED/WHT
Ignition Pwr : RED/GRY
Ground : BLK
Illumination : BLU/RED
Dimmer : ORG
Power Ant. : GRN/RED
Harada Part : FM-72A
Front Speakers *
Kit : 2 5/8" DEPTH
RF(+) : VIO/YEL
RF(-) : BLU
LF(+) : GRN
LF(-) : BRN/RED
Rear Speakers *
RR(+) : BLU/WHT
RR(-) : BLU/PNK
LR(+) : BRN/YEL
LR(-) : BRN/LT.BLU
jefferskn is offline
post #7 of 17 Old 04-03-2007, 04:09 PM
Krank
I have a tach wire question for those who in the know. Is there another option for a tach wire I can use to get a tach signal other than reaching all the way into the passenger rear side of the engine bay? The tach signal input wire on my remote start unit is really short, probably a 1.5 feet long. What have others done?
My remote starter starts cranking and then stops before fully starting, so I'm assuming I have a bad tach signal wire.
Thanks guys.
Krank is offline
post #8 of 17 Old 04-03-2007, 08:41 PM
BradMB2004
what brand and model are you using?
does your alarm flash the brake lights when the remote start is used?
some alarms will kill the engine if you hit the brake light, if the brake lights flash in doing so it will kill the engine immediatly after start up. you will have to add a diode on the brake light trigger if this is so.
tach signal is also something good to look at. you should be able to attach it to the negative side of the coil.
www.alldata.com is gonna be your best source for vehicle wiring diagrams. It's $25 a year for 1 VIN and $15 for each additional VIN
Brad
2004 Wrangler X
2001 Grand Cherokee Ltd.
1997 Grand Cherokee Ltd.
BradMB2004 is offline
post #9 of 17 Old 04-03-2007, 08:59 PM
OffroadZJ
OffroadZJ's Avatar
trust me, I do approx. 4-6 remote starters a day... if you dont know your way 100% with electrical stuff, DO NOT do it yourself. The $100-$150 you will spend will save you approx. $500-$1000 when you accidentaly cross a wire and fry something. I have done well over 300 total in the past 3 years, and I still hate doing them... even though I can usually get the finished in about an hour on average.
1994 5.9L ZJ. RK 7" long arm, 35" Super Swamper Trxus M/T mounted on Pro Comp extreme alloys. Ford 8.8 w/ 4.10 and powertrax locker, hp30 w/ 4.10 (open for now), Warn Tabor 9000. Soon to come: Hanson Enterprise front winch bumper, hand made rear bumper with carrier, hand made skid plates. 242 case is sitting in my garage waiting for a warm day to transplant.
OffroadZJ is offline
post #10 of 17 Old 04-03-2007, 09:17 PM
BradMB2004
what he said^
it'll make ya do this
Brad
2004 Wrangler X
post #11 of 17 Old 04-03-2007, 09:39 PM
OffroadZJ
OffroadZJ's Avatar
i really have actualy done that before... put a nice dent in one of our garage doors... lol. My boss gave me the rest of the day off (not as punishment either... lol).
post #12 of 17 Old 04-03-2007, 09:47 PM
Vestjam
Thanks guys.
When I did mine, I ran the wire out into the engine compartment for the tach and then ended up not even using it because the alarm/remote start 'learned' after startup and didn't need the tach to know the vehicle was running. I think it picked up from the run side of the ignition, but why question it, it works fine.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #13 of 17 Old 04-03-2007, 10:16 PM
OffroadZJ
OffroadZJ's Avatar
did you ever teach the tach to the system? Look for the tach learn routine in the install manual. if you dont have to use it, dont.
post #14 of 17 Old 04-05-2007, 07:42 PM
SBlackfoot
I went to my coil wire, no sweat. Same to my minivan, no issues whatsoever.
They're really not that hard to install if you take your time and plan things out ahead of time. Track down the necessary wires ahead of time, test them before hooking them up to verify they're the right one, read the manuals, neatly solder all joints. No offence but guys saying you'll save $1k in repairs if you try it yourself are pretty much just trying to sell labour.
'98 Grand Cherokee Limited, 5.9L, daily driver.
'98 Grand Cherokee Limited, 5.9L, $650 project.
'93 Grand Voyager wheelchair van, 3.0L, chick magnet.
'90 Trans Am GTA, 5.0L/700R4.
'98 Oldsmobile LSS, 3.8L.
SBlackfoot is offline
post #15 of 17 Old 02-09-2013, 09:09 AM
ksebeny
Originally Posted by buz0340 View Post
hi,
thankyou,
brian
Hi Brian,
Did you ever get an answer to your question? My son and I are also trying to install a remote starter on my 2004 Jeep cherokee and I can't find a wiring diagram that matches the color of the wires. Did you ever find an accurate color wiring diagram?
thanks, Kathy
ksebeny is offline
Auto headlights flashing after remote starter install SBlackfoot ZJ Grand Cherokee Forum 0 01-24-2009 08:16 PM
Swith Wiring Diagram - remote start install trouble CommanderStevo WK Grand Cherokee & XK Commander Forum 3 09-14-2008 06:46 PM
remote starter for WJ? phish832 ZJ Grand Cherokee Forum 1 12-05-2006 07:18 PM
Remote Starter shashank ZJ Grand Cherokee Forum 23 09-03-2006 03:38 PM
Remote Starter, once again Jayrod586 ZJ Grand Cherokee Forum 6 12-22-2004 06:59 AM
