wire problem? - JeepForum.com
post #1 of 3 Old 12-28-2003, 06:46 PM Thread Starter
rollerbones
wire problem?
Hi, I seem to have a problem with my 97 Grand Cherokee I just bought. The Horn does not work, fuse is fine and so is the relay (can hear click when pushed). Also, the drives heated seat does not work (I do hear the relay under it click) and the inside chime does not work. Could all this be linked somehow? All the fuses seem fine.
THanks for any help.
Tom
rollerbones is offline
post #2 of 3 Old 12-30-2003, 01:15 AM
RockPaws
RockPaws's Avatar
Have you checked for power at the horn? Use a test light or volt meter, then have someone press the horn switch. May just be a bad horn or it could be disconnected.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #3 of 3 Old 12-30-2003, 05:15 AM Thread Starter
rollerbones
Yep, and last nite when I locked the doors the horn chirped at me, softly but it did chirp and the inside chime worked...must be a loose wire somewhere.
4 wire o2 sensor, which one is the signal wire? Kramer H ZJ Grand Cherokee Forum 1 10-08-2009 06:47 AM
1998 AC wire problem chrisbean ZJ Grand Cherokee Forum 1 03-11-2009 07:39 PM
Engine harness wire to coil pack wire is frayed dustindu4 ZJ Grand Cherokee Forum 1 06-26-2008 12:18 PM
HELP!!! Fog Light Wire Problem!!!! BlaineWasHere ZJ Grand Cherokee Forum 15 03-02-2005 11:29 AM
Wire to Tap? Super8 ZJ Grand Cherokee Forum 1 08-18-2003 01:56 AM
