Wipped out front right axle - JeepForum.com
post #1 of 4 Old 05-05-2005, 10:01 AM Thread Starter
b_critical
I just purchased this 96 JGC 4X4. The front right axle is totaly wipped out I have removed the shaft now I need to fix it. What recommedation do the guru's on this page request. I also noticed that CV boot on left side is twisted.
Should I replace both CV Half shaft and inner seals and fluid?
Of maybe switch to Ujoint style?
I am not completly understanding how the unit goes together because Is all wipped out it looks like the outer bearing is gone.
Does anyone have a good diagram or maybe pics of how this setup is supposed to look so I know what I need.
I could get whole axle and hub assebly at junk yard and replace also or should I diffently by new?
Thanks in advance
Bill
b_critical is offline
post #2 of 4 Old 05-05-2005, 05:23 PM
blkfreedom03
blkfreedom03's Avatar
If the boot is torn and its clicking im pretty sure its time for it to be replaced altogether.
Word of advice, pay the extra money for the good one. I was cheap in buying one for my driver's side a year ago and last night the joint literally blew apart because of the 249 t-case binding up in a parking lot. The boot on the broken joint was all mangled and twisted, very unlike the other side where the boot was nice and even.
U-joint conversion and 242 case coming soon
Good luck with your new purchase BTW, you will love it.
Present: '03 Wrangler Freedom Ed. 4.0/NV3550 - Dynomax cat-back, 30" BFG ATs, black steelies..
Past: '94 ZJ Laredo 5.2/46RH
Black Jeep Society
blkfreedom03 is offline
post #3 of 4 Old 05-06-2005, 12:27 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
is this what you need?
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #4 of 4 Old 05-06-2005, 12:44 PM Thread Starter
b_critical
perfect thanks might you have one for the rear bumper cover bumper and braces.
I can't figure out how you remove the braces from Jeep I want to get a good set at junk yard but I got tofigure out how to get them off.
Bill
Axle Shafts, Gerotor Pumps, Clutch Plates,... oh my! Is my front axle a vari-lok? 99avant WJ Grand Cherokee Forum 16 08-11-2011 09:47 PM
4x4 front axle oil vs rear axle oil sdowney717 ZJ Grand Cherokee Forum 13 07-09-2009 11:45 PM
changing front axle shaft..axle nut lakailimited06 ZJ Grand Cherokee Forum 2 06-14-2009 09:40 AM
swapped front axle, little or no front bakes now rannej ZJ Grand Cherokee Forum 8 02-25-2009 11:46 PM
Replaced front axle/CV joint now a bad whining from front end? f1rz06 ZJ Grand Cherokee Forum 4 09-16-2004 03:48 AM
