Wipers... Slow and Stop... - JeepForum.com
post #1 of 5 Old 01-02-2013, 07:38 AM Thread Starter
congerz83
On my way to Pittsburgh this weekend I noticed my wipers were getting slower and slower as I continued along.
Today (very cold) my wipers went up and then stopped... I tried to gently tug on them to get them back down, but the wouldn't return...
A few minutes later then SLOWLY went back into position on their own...
I'm pretty sure that I'll need a new motor, I was just wondering if there was any "ZJ-Magic" I could perform with a soldering iron. Possible bad connections?
congerz83 is offline
post #2 of 5 Old 01-02-2013, 07:57 AM
newfieZJ
If you got the time , you could try disassembling the motor . The only write up I know of is for the rear . Principle will be the same if that helps . Try that and greasing the plastic grommets on the wiper arm assemblies http://www.jeepforum.com/forum/f13/s...-motor-398760/
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 5 Old 01-02-2013, 09:15 AM Thread Starter
congerz83
I thought there may be an easier way out... Thanks Newfie....
post #4 of 5 Old 06-12-2013, 01:35 PM Thread Starter
congerz83
I don't like leaving things open ended... I was able to fix the motor myself... I took apart as much as I could, cleaned out all old grease and sprayed it inside and out with brake-cleaner... Greased it back up, and it works like a charm.
Before anyone spends money on a new motor... GIVE THIS A TRY! NOT HARD AT ALL!
post #5 of 5 Old 06-13-2013, 12:51 AM
Billyjoebob007
It could also possibly be the turn signal lever needs replaced, my wipers on my Trans am were doing the same thing, the wiper motor for it is expensive so i replaced the turn signal lever for $30 and that turned out to be the problem fortunately ! Ive never done one on the ZJ but its looks perhaps a bit more work to install, dunno,The TA one just pulls right out and pop the new one in.
ZJ
http://www.ebay.com/itm/New-Turn-Sig...cd2a64&vxp=mtr
Billyjoebob007 is offline
