-   -   Wipers... Slow and Stop... (http://www.jeepforum.com/forum/f13/wipers-slow-stop-1457640/)
congerz83 01-02-2013 06:38 AM
On my way to Pittsburgh this weekend I noticed my wipers were getting slower and slower as I continued along.
Today (very cold) my wipers went up and then stopped... I tried to gently tug on them to get them back down, but the wouldn't return...
A few minutes later then SLOWLY went back into position on their own...
I'm pretty sure that I'll need a new motor, I was just wondering if there was any "ZJ-Magic" I could perform with a soldering iron. Possible bad connections?
newfieZJ 01-02-2013 06:57 AM
If you got the time , you could try disassembling the motor . The only write up I know of is for the rear . Principle will be the same if that helps . Try that and greasing the plastic grommets on the wiper arm assemblies http://www.jeepforum.com/forum/f13/s...-motor-398760/
congerz83 01-02-2013 08:15 AM
I thought there may be an easier way out... Thanks Newfie....
congerz83 06-12-2013 12:35 PM
I don't like leaving things open ended... I was able to fix the motor myself... I took apart as much as I could, cleaned out all old grease and sprayed it inside and out with brake-cleaner... Greased it back up, and it works like a charm.
Before anyone spends money on a new motor... GIVE THIS A TRY! NOT HARD AT ALL!
Billyjoebob007 06-12-2013 11:51 PM
It could also possibly be the turn signal lever needs replaced, my wipers on my Trans am were doing the same thing, the wiper motor for it is expensive so i replaced the turn signal lever for $30 and that turned out to be the problem fortunately ! Ive never done one on the ZJ but its looks perhaps a bit more work to install, dunno,The TA one just pulls right out and pop the new one in.
ZJ
http://www.ebay.com/itm/New-Turn-Sig...cd2a64&vxp=mtr
The time now is 02:24 PM.
