Wipers don't Park or have Intermittent. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Wipers don't Park or have Intermittent.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-28-2013, 11:19 AM   #1
Catfish33
I have checked the Relay in the PDC and swapped to a known to have been working BCM and my wipers are still wonky. They have no intermittent at all and when I shut them off they still swipe about 3-4 more times then stop wherever they damn well please. Could there be something wrong with the wiper motor itself. Oh and If I use the auto headlight function and use the wipers the headlights will shut off and come back on at times.
97' TJ 2.5L, 5-speed, 4.10 geared stock Dana 30 front a nd Dana 35 rear, 3.5" home built lift. Waiting to install the 4.5" coils. 33X12.50-15 Trxus M/T's "The Black *****" 65' Kaiser/Jeep Gladiator 230 Tornado OHC 6cyl., 3-speed, 4.27 geared Dana 44 closed knuckle front end and fully locked Dana 53 rear. 36X12.50-16.5 Goodyear Hummer Tires. "Mean Green"
Catfish33 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2013, 01:54 PM   #2
dellis
The wipers work properly when they are NOT on an intermittent setting, right? If so, your motor is fine.
On the intermittent settings, wipers work with a simple capacitor circuit, which is located in your BCM. When you set your wipers on either low or high, the BCM is not involved, and the switch activates the wiper motor directly.
So, your problem lies either in your column switch or your BCM.
dellis is offline   Reply With Quote Quick reply to this message
Unread 06-28-2013, 02:03 PM   #3
Catfish33
Low and High work fine but they don't stop when I shut them off right away. They will wipe a few more times then stop wherever.
Unread 06-28-2013, 03:42 PM   #4
um7267
so they don't end in the normal resting place?
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2013, 03:54 PM   #5
Catfish33
No and the don't stop as soon as I turn them off either.
Unread 06-28-2013, 07:38 PM   #6
leftfield6
Where are my damn keys?
leftfield6's Avatar
Mine has the same exact behavior. I'm not sure how to tell if it's the box or the multi-switch.
Jeepless for now, probably not for long
(former)
98 Grand Cherokee Limited 5.9
98 Grand Cherokee Laredo
77 CJ-5
75 CJ-5
leftfield6 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2013, 07:42 PM   #7
um7267
did you check the relays? you could try to disassemble the wiper control and clean the contacts
Unread 06-28-2013, 10:28 PM   #8
Catfish33
Are there multiple relays or just the one?
