Wiper delay not working correctly - JeepForum.com
post #1 of 10 Old 12-19-2016, 12:50 PM Thread Starter
Zilliver
Hello Guys,
So I changed out my turn signal assembly by the steeringwheel - I had two last speeds, no delay speed. Also the window washer button was very loose and activated all the time when I was indicating turns.
So I put on a new one and tested it with a ignition on - all the wiper arm delays work good.
But when I start the car I only have the last two speeds. The delay speeds are gone when the engine is running.
Is it the wiper module, that needs re-soldering?
95 Grand Cherokee 5.2
Zilliver is online now
post #2 of 10 Old 12-21-2016, 12:44 PM
robalex51
bump
robalex51 is offline
post #3 of 10 Old 12-21-2016, 04:00 PM
LordHobbit
That's interesting.
on my '93 it takes only a few minutes to pull out the delay module and take a look. If you see it burnt fix it.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 10 Old 12-22-2016, 12:31 AM Thread Starter
Zilliver
I will check it on Sunday, just thinking, if it can be something else.
post #5 of 10 Old 12-30-2016, 03:08 PM Thread Starter
Zilliver
Update:
The wiper module was good, no burned tracks, also changed all the capacitor for a try. But still nothing.
The relay in the module clicks, but very quickly, I dont know why. I also checked the resistance from the signal assembly - the resistance changed good, when turning it on delay speeds.
What next?
post #6 of 10 Old 12-31-2016, 03:43 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Odd that it works one way and not the other. I would get my hands on a wiring diagram to see how source voltage is switched.
Originally Posted by HighLonesome
coralman is offline
post #7 of 10 Old 01-07-2017, 09:14 AM Thread Starter
Zilliver
Update: So when its cold, the box works ok, but when its warm inside the car, then its not.
Im trying to swap up the transistor tomorrow and see if it change something.
Really dont know what is touchy to temperature in there.
post #8 of 10 Old 01-09-2017, 08:03 AM
LordHobbit
solder joints. It is probably contacting when the cold contracts it all, but the heat expands it and it stops contacting. Take it back out and look over all the solder joints. If one looks iffy, reflow it.
post #9 of 10 Old 01-12-2017, 10:18 AM Thread Starter
Zilliver
Solder joints seemed OK.
But I have a new working module and I can test the old one more.
I will report back, if I find the real problem.
post #10 of 10 Old 01-15-2017, 08:51 PM
papitt
FUNNY MINE DOESN'T WORK CORRECTLY Either but mine when put where delay should be is just on low speed.. It stays on low for about 10 minutes then it'll cut off & It'll wipe again in about 3 minutes. Turn it off & It'll start over & wipe on low for a good while but then it shut off. I was wondering if mine was in the motor .
papitt is offline
