Windshield Wipers Moving Very slow .... is motor bad? - JeepForum.com
post #1 of 11 Old 02-07-2007, 08:33 AM Thread Starter
mmstone
Good Morning All!
My wife called me today and said that the windshield wipers on her 97 ZJ are moving very slow. I noticed that they were a few days ago as well.
The intermittent feature works, but when your turn the switch to what should be the fast setting they do not move as fast as they once did.
I think it sounds like the motor is on the way out, but I didn't want to swap it out until I got some other opinions.
Thanks guys!
mm
1997 GC Laredo 4.0 I6, Selec-track, 242 Xfer Case, 3.73 Rear, Rebuilt Transmission, 165K
mmstone is offline
post #2 of 11 Old 02-07-2007, 02:10 PM
CTORT
that or maybe a bad ground.
"Off-road aficionados, the wacky breed who enjoy spending hours moving mere metres over seemingly impossible obstacles, are almost universally Jeep owners."
'99 WJ 2"BB, other goodies, every best/possible OEM option except block heater.
'89 XJ 7.5"lift, lock f/r, 35's, Ford 8.8", other goodies.
'75 CJ-5 5"lift, locked, 33's, Built 360, T-18a, Dana 44, other goodies.
CHECK OUT my gallery
CTORT is offline
post #3 of 11 Old 02-07-2007, 02:18 PM
2tone93zj
not sure what the weather is like wehre u are...but up here its -41 and my windshield wipers will move slow.....but when its warmer they work fine.
1993 Jeep Grand Cherokee Laredo
I-6, 42re, 249-->242 selec-trac swap, D30/D35
31x10.5, 3.5" IRO F>R, skids and tow hooks
Wanted: 93-95 Keyless entry fob
BUILT NOT BOUGHT #204
2tone93zj is offline
post #4 of 11 Old 02-07-2007, 02:38 PM
starbunas
Check your voltage meter when it happens. If it drops it could be a loose belt or alternator going bad too.
starbunas is offline
post #5 of 11 Old 02-07-2007, 02:50 PM
ajmorell
ajmorell's Avatar
Yeah, mine move a little bit slower when it's cold out so that may be it. I also noticed that mine had iced up a little bit near the bottom of the arm, so I cleaned that out a little bit and that helped as well.
ajmorell is offline
post #6 of 11 Old 02-07-2007, 02:58 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Funny offtopic story: back when wipers were run off off vacuum depending on whether you had it floored or not determined the speed. At idle they would just crawl (barely move) but if you punched the gas they would zoom off as fast as possible
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #7 of 11 Old 02-10-2007, 10:29 AM Thread Starter
mmstone
Replaced motor and nada ...
I just finished replacing my winshield wiper motor to no avail. The still have no fast setting. I looked at the voltage and it drops a little bit, but nothing to dramatic.
I'm thinking either a bad switch or the linkage needs cleaned up and greased.
Has anybody performed either of these two procedures?
Any other thoughts?
THanks!
Jeff
mmstone is offline
post #8 of 11 Old 02-10-2007, 12:30 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Any other thoughts?
THanks!
Jeff
When it gets really cold, mine slows down a lot as well. I used lithium grease on the motor on the output rod and it sped up quite a bit, but still not to full speed. I did the same to the rear motor because it would get stuck in the middle of it's stroke. The grease has kept it from sticking.
I would clean your linkage and try lithium grease on the motor rod. If that doesn't help, time to start double checking or replacing electronics.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #9 of 11 Old 02-10-2007, 02:19 PM
ForwardControl
Wow, really? Vacuum wiper actuators??? I had no idea...
Matt
2000 WJ Laredo (Champaign), 4.0L, 242 SelecTrac. Added: Black front hooks. K&N FIPKII Intake. RB1 Navigation, Mopar iPod Integration. 31" BFG All Terrain T/A KO. Alpine audio upgrade (see link below). Next: IRO 3" Lift, new shocks.
I HAVE A 4.0L In My WJ And LOVE It So *** Me Club Member #1
Colorado Jeep Club Member #114
ForwardControl is offline
post #10 of 11 Old 02-10-2007, 02:54 PM
niko
niko's Avatar
Mine slow down when it's cold too.
I just got new wipers and it helped speed them up quite a bit.
niko is offline
post #11 of 11 Old 02-10-2007, 04:52 PM
KingPrat
My GTO even has electric wipers.... and it's a 67.... You gotta be talkin 40s-50s or earlier.
But yeah, to stay on topic, very cold weather will slow everything down. It was 12 degrees here ther other night and my wipers were crawling across my windshield
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust
Nokian Vatiiva tires: 235/65-17
Previous:1997 ZJ TSi 4.0. Some stuff added
Western New England College '08
Golden Bear Lacrosse #13
Week 11 USILA Rank: #15
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
Windshield Wipers Cons ZJ Grand Cherokee Forum 6 12-22-2009 11:49 AM
Windshield Wipers Not Working ZJeepMI ZJ Grand Cherokee Forum 4 07-06-2008 09:05 PM
Wipers way too slow for my liking rxl ZJ Grand Cherokee Forum 16 11-20-2006 09:57 AM
Windshield Wipers SPZEE ZJ Grand Cherokee Forum 1 06-15-2006 12:23 PM
Windshield wipers???? TwistWrist6 ZJ Grand Cherokee Forum 19 11-03-2004 09:49 PM
