Windshield Wiper relay fuse? - JeepForum.com
post #1 of 23 Old 05-08-2005, 08:15 PM Thread Starter
coolest_Stan
My windshield wipers stopped working. I thinkt he problem is with my fuses. SO I am going to remove the fuse (in the pbc, the black box next to my battery under the hood) for my windshiled wipers, because I am thinking that the fuse is blown. My problem is that I don't know which one is the fuse for the windshield wiper. Most of the fuses are labeled, like ABS or engine starter, or A/C, but there is not one for windshield wipers.
There is one that says Alt 1, and another that says Alt 2. Could these be the fuses for my wipers?
Also, my stereo no longer works either (stopped working the same time my wipers stopped working), which makes me even more convinced that it is because I blew one of my fuses.
Any help appreciated.
Thanks!
93' Grand Cherokee Limited 4.0 L 190 hp 4x4
235x75 BFG Goodrich A/Ts
K&N Drop In Filter
New Coolant Resevoir Cap
Current Projects:
coolest_Stan is offline
post #2 of 23 Old 05-08-2005, 08:55 PM
nashmd454
nashmd454's Avatar
hey Stan...it is the bottom left one. I took photos of it and will post it in my photobucket sig. You can go there to see.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #3 of 23 Old 05-08-2005, 09:00 PM
nashmd454
nashmd454's Avatar
by the way Stan...is just the intermittent wipers not working and low and high speed working...or do they not work period. If the relay doesn't work then it may be the multi function switch on the steering column. Hope it is just the relay (13$ part at pep boys).
post #4 of 23 Old 05-08-2005, 09:10 PM
Guumba
Guumba's Avatar
I think the relay box is different for a 93 vs a 96, I too have been searching for the relay and my relay box looks completely different than yours... On the lid there is nothing that says windshield wipers. Is there another place where it might be?
1998 Jeep Grand Cherokee Limited
AKA "The Black Stallion"
120k on the clock.
Black inside and out.
5.2 Litres of gas guzzling power.
** TOTALED! UGH! **
Guumba is offline
post #5 of 23 Old 05-08-2005, 11:26 PM
nashmd454
nashmd454's Avatar
I don't know what to tell you...I figured that from 93-98 they were alike. I can suggest pulling a good relay and swapping out with the rest and hopefully you will find the bad one. Meaning turn on the wipers and start swapping relays till the wipers come on. If that doesn't work then it isn't the relay. Could you post a pic of your pdc and maybe I can see what yours looks like and research from there.
post #6 of 23 Old 05-09-2005, 12:29 AM
-Joe-
-Joe-'s Avatar
If its any help this is the fusebox of a 95. I think the wipers are controlled by the wiper module under the driver side kick panel, not a relay.
The radio and wipers are on different fuses on the 95..
Radio is #19
Front Wipers #27
hope it helps.. when you pull the fuse cover off there should be a diagram on the cover..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #7 of 23 Old 05-09-2005, 10:51 AM
Guumba
Guumba's Avatar
I just figured out there is a relay center under the glove box in a 93-95 grand. I wonder if one of the relays under there would control the wipers? I can't find a diagram showing what they go to though. I'll take a picture of it later on. There is like 4 bigger relays about 4 smaller relays. If anyone knows what they are maybe this could help us out.
120k on the clock.
** TOTALED! UGH! **
Guumba is offline
post #8 of 23 Old 05-09-2005, 01:31 PM Thread Starter
coolest_Stan
thanks for all the support guys. I just started my jeep up again today and miraculously the wipers and stereo started working again.
So I think my problem is jsut a loose wire somewhere. I will leave this at that, Ill make anotehr thread abotu loose wires. so all the other people can get help with their fuse problems.
nash md, to answer your question, both of them dont work. Before, my wipesr would only work on high and low. ANd then they stopped working at all. But i think I can solve the problem, I will just solder the dead wire under my drivers side kick panel. However I still dont know why my wipers will sometimes just stop working entirely
thanks guys
K&N Drop In Filter
Current Projects:
post #9 of 23 Old 05-09-2005, 06:59 PM
Guumba
Guumba's Avatar
I found the module deal and it definitly controls it. Now I am not sure what is going on with mine. I busted out the volt-meter and did a couple tests. When I tested the switch harness, power came thru on all different speed settings. The same amount of power went through the module when connected to the switch. The grey harness (which goes to the wipers) when connected to the module shows nothing on the voltmeter. Why would the switch send power, the module show the exact same thing but nothing goes into the wiper harness?
120k on the clock.
** TOTALED! UGH! **
Guumba is offline
post #10 of 23 Old 05-09-2005, 10:04 PM
-Joe-
-Joe-'s Avatar
guumba
What problem are you having? not working at all?
- Joe -
-Joe- is offline
post #11 of 23 Old 05-09-2005, 10:16 PM
-Joe-
-Joe-'s Avatar
- Joe -
-Joe- is offline
post #12 of 23 Old 05-10-2005, 02:07 PM
Guumba
Guumba's Avatar
guumba
No, I have high and low speeds but I don't have any of the intermitant speed settings. Also, the wipers don't reset when turned from low or high settings.
120k on the clock.
** TOTALED! UGH! **
Guumba is offline
post #13 of 23 Old 05-10-2005, 02:50 PM Thread Starter
coolest_Stan
i have the same problem as guumba.
my wipers work now, they jsut only work on high and low, adn they don't reset.
guumba: did you try looking under your drivers side kick panel, and removing the ciruit board with two screws in it? Look there, and see if there is bad wiring
K&N Drop In Filter
Current Projects:
post #14 of 23 Old 05-10-2005, 03:29 PM
Guumba
Guumba's Avatar
All I see under the kick panel is the wiper module and another set of wires which goes into the door.
120k on the clock.
** TOTALED! UGH! **
Guumba is offline
post #15 of 23 Old 05-12-2005, 05:04 PM Thread Starter
coolest_Stan
ahh.. never mind. There is no such thing. I was misinformed. Try looking inside the wiper module and see if any wires are gone. I looked inside mine, but all the wires seem o.k.
What else could cause my intermittent wipers to go dead?
K&N Drop In Filter
Current Projects:
windshield wiper fuse # ttavenieriii ZJ Grand Cherokee Forum 9 06-25-2013 10:22 AM
Wiper relay location? psychoworks ZJ Grand Cherokee Forum 4 02-28-2011 07:11 PM
Where is my intermittant wiper relay in my PDC 94 ZJ 4.0 I6 littlefdl ZJ Grand Cherokee Forum 4 05-20-2009 06:05 PM
Intermittent Wiper Relay??? ftfd617 ZJ Grand Cherokee Forum 5 02-25-2007 02:02 PM
Intermittant Wiper Relay??? PHDinYJ ZJ Grand Cherokee Forum 2 04-12-2005 12:16 PM
